Results 1 to 12 of 12
Thread: THANK YOU! THANK YOU! THANK YOU!
    Just opened the pool this weekend. Took the cover off and this is what I found.
    [attachment=0:23kfu3yi]poolopening.jpg[/attachment:23kfu3yi]
    Followed the very simple and wonderful advice in this forum and this was the easiest pool opening EVER.
    Can't say enough about TFP!
    13,100 gal (?) IG Plaster Pool, Rectangular (30 feet long, 11 feet wide at 3 feet deep shallow end, 14 feet wide at 6 feet deep end.)
    Pentair Challenger 1hp 2 speed hardwired pump
    Triton II T60 sand filter
    P153 Intermatic digital timer control
    8 gal Liquidator with 3/8" upgrade
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: THANK YOU! THANK YOU! THANK YOU!
    I think you just did.
    Butterfly's Avatar
    South Carolina
    10,045
    Your pool looks fabulous!
    Another happy BBB'er
    You're done SLAMing when:
    Thanks Butterfly!
    30,403
    BT,
    Wow! That's pretty nice! Remember to give yourself credit.
    BBB is all about learning pool water management and not letting someone else tell you what to do. You've obviously learned very well.
    May 2011
    lebanon tn
    370
    Nice looking pool!
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    BT,
    thanks!
    BUT DONT LET MY BETTER HALF HEAR YOU SAY THAT!
    Speaking of management, pool numbers:
    FC: 5 - liquidator up and running.
    CC: 0
    TC: 5 - measured after 24 hour pump run.
    TA: 70
    Ph: 8.2 - YIKES!
    CH: 350
    CYA: 20
    Borates: 30
    Temp: 70 degrees
    all in all Im very happy at those numbers.
    You probably know this but PH is high and CYA is low. I would also raise borates, even though it is alright where it is, it will tend to go down over the course of the pool season.
    man, cant even catch a break in here! Wifey last evening: "there are some leaves in there, you going to get those out?"
    Aug 2010
    Dallas, TX
    4,052
    If your home is like mine, it is the wife that wanted a pool. I tell her go get them out herself.
    Then I go get the leaves out.
    Lucky for me the pool came with the house we bought so I didnt have to shell out the dough. Yeah, I've said that a few times. Wasn't pretty.
