Thread: Plugging skimmer equalizer tube for winter
    Jul 2010
    Reno, Nevada
    22
    Just opened our in-ground, gunite pool which we had re-plastered last summer along with skimmer replacement. The skimmers have equalizer tubes with openings in the pool wall below the skimmers. When I winterized, I dropped the water level below these equalizer lines, blew them out, and capped both ends of the lines using lots of Teflon tape on the plugs. But when I pulled the plug inside the skimmer off this week, the equalizer tube was full of water in both skimmers! (I hadn't pulled the plugs in the pool wall yet.) Apparently both wall plugs leaked that much water during the course of the winter.
    Would I have been better off not plugging the equalizer tube inside the skimmer giving the water -and ice - somewhere to go? My old skimmers had spring-loaded caps on the equalizer tube inside the skimmer, so I never attempted to plug them there.
    No apparent damage was done. Maybe I was just lucky.
    25K gal gunite pool with Auto Cover and Meyco mesh winter cover. Pump and filter in underground vault below level of returns. New Pebble Fina plaster in 7/2010.
    22,553
    Re: Plugging skimmer equalizer tube for winter
    If you pump the water below the equalizers then I wouldn't plug it.
    Jul 2010
    Reno, Nevada
    22
    Neglected to mention that I refilled the pool after installing the plugs as required to support my winter cover and keep the new plaster covered with water as much as possible. Refilled to just below the tile line and main skimmer opening.
