Thread: blue spots
    Sep 2007
    Gloucester County, NJ
    141
    blue spots
    don't have numbers right now (will tomorrow), but I have noticed 3 locations of blue spots in my new gunite/white plaster pool. When going underwater to see the spots, they look like individual blue crystals, as if they were quartzite, but it shouldn't be as I did not have quartzite installed. any thoughts? I ahve tried the spot acid and trichlor treatments with no change. I have also tried one of those stain removers for the pole and waterproof sandpaper....no changes.
    28,000 gallon gunite/white plaster with 30ft RBB and 2ft sheer descent, 100 sq ft thermaledge, 50sq ft spa w/ 6 jets
    2HP Jandy pump, 60sq ft Jandy DE filter, 400,000 BTU Jandy LX Nat Gas Heater, 2 Jandy color lights + Jandy color spa light, Jandy Aqualink RS6, Jandy AquaPure 1400
    mbar's Avatar
    Ashland PA
    257
    Have you used any copper products in the pool?
    16x33 fiberglass pool sand filter
    Sep 2007
    141
    no, no copper products. we have well water, but have never had copper test positive, only iron.
    30,432
    Since you have put none in your pool, I doubt copper is the issue.
    Blue is unusual enough that I also suspect it is not a staining issue.
    Can you examine it closely to determine whether or not it is something erroneously imbedded in the plaster?
    Sep 2007
    141
    Exactly my thought...I spoke with the PB yesterday. They are going to come out to look as they couldn't figure it out either by describing it.
