Thread: Possible to clean your heater gas regulator valve?
    My heater just stopped working last year .... worked fine in the spring then wouldn't start in the fall. I by-passed all the switches to make heater come on, nothing happened. Am thinking it is the regulator valve. Pilot works fine. New valve is $350 .. can I try to just clean it first? If so, what is the best way to do it?
    36K gal, concrete, A O Smith 1HP pump, Jacuzzi Tri-clops cartridge filter, heater
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Re: Possible to clean your heater gas regulator valve?
    I got some good tips in this thread last year: post187179.html#p187179 .
    If you know your heater make and model, you can probably find the manual on line. The LAARS (now Jandy) manuals have a good troubleshooting section.
    Good luck!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    It could be the pilot generator. Check the voltage coming from the pilot generator. It should match the specs in the manual.
    Support the site
    May 2008
    Long Island, NY
    151
    Try tapping the valve. My heater valve doesn't open when the heater (Hayward H300 NG) calls for heat. If I tap the valve (usually use the handle of a screwdriver) it will open. It closes OK, it just doesn't like to open.
    Pool Details: 25,440 Gal IG Vinyl 21x40 Mountain Pond (Graphex)
    Filter: Hayward Micro-Clear DE (48 Sq Ft)
    Pump: Hayward SP2603VSP VS Super Pump
    SWG: Circupool Si45
    Cleaner: Pentair Kreepy Krauly Prowler 820
