Thread: hose repair
    May 2011
    houston texas
    1
    hose repair
    i have a splash AGP omega series 20' my blue return hose (filter to pool) has a hole in it,, it looks like it is made out of a rubber type compound with the spiral wire in it. what is the best thing to patch this small 1/4" slit type hole in it? thanks for any advise.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,424
    Re: hose repair
    The split will continue to grow. You can measure the length and diameter of the hose and go to Lowes, or Home Depot to buy a replacement hose. Most hardware stores will have it by the foot in the plumbing section. Check your clamps that connect the hose to the pool equipment and replace if needed.
    Love TFP? Become a
    TFP Supporter!
    May 2011
    lebanon tn
    370
    Re: hose repair
    if you look up flex pvc pipe online, you can probably get it cheaper than Home Depot/Lowes- my hose has a similar leak, pricing at HD/Lowes/Pool Store was $5-6 / ft, think I found it online at $1.99/ft; depends on how much you need, though, because shipping was $25 I think...
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
