Results 1 to 9 of 9
Thread: Plugging a hole in PVC pipe
    Dec 2010
    San Diego, CA
    1,137
    I'm contemplating moving some connections for the LQ around. I want to try putting the suction tube into the drain plug opening In the pump but this will leave me with a hole in the suction pipe between the pump and the valve that switches from the skimmer to the cleaner. Any ideas short of cutting and patching the pipe with a fitting etc? I have a dear mr pool builder pad so that option is not very appealing...
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    30,402
    Re: Plugging a hole in PVC pipe
    You can simply cut the LQ hose up near the PVC and insert a barbed plug into the hose. I did that with mine for a while and it was so unprofessional looking I considered building a birdhouse (or something) around it so people wouldn't see it.
    I finally did it correctly and neatly with a PVC coupling....took me about twenty minutes!!
    May 2011
    lebanon tn
    370
    There are "patches" available for PVC- or you can even make one, depending on the size pipe you have;
    the patches are 2 pieces that wrap around the pipe, with a rubber gasket, then a screw to hold together.
    You can do your own by cutting a coupling lengthwise, then glue on to outer shell...
    but, as duraleigh points out, the actualy cut and install normal coupling shouldn't take long... and much more professional appearance!
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    22,542
    You could tap the hole and thread a plug in it. That doesn't look too bad.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Almost anything will plug a hole on the suction side. If you think you might ever use that hole again, you can use several things as plugs. Hot glue, caulk or plumbers sealer will all seal the hole and prevent air leaks plus they can be removed at any time. My preference is hot glue since the drying time is very short.
    Mark
    solarboy's Avatar
    Aug 2010
    Europe
    337
    You can also use an irrigation clamp connector with a plastic bolt in it.
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
    I have several holes in my PVC plugged... Save those bad/failed Jandy/Pentair/Compool/Hayward temperature sensors - they fit perfectly!
    ~45Kg Pool with attached Spa, NSP-72 DE, Minmax 400 Heater, Tahoe Blue Pebbletech, Jandy SWG via Aqualink RS-8, The Pool Cleaner (black)
    Pumps: X3 Hybrid Pump (switches to SPA), 2HP Spa (additional, when SPA is on), and a 1HP For Waterfall
    8, 4x12 Solar Panels on the roof of the pool-house (~12' up)
    CAPTAIN JAMES T. KIRK: "I'M SORRY. I CAN'T HEAR YOU OVER THE SOUND OF HOW AWESOME I AM" (Thanks to TFP!)
    Dec 2010
    San Diego, CA
    1,137
    This will be my temporary solution. A permanent PVC coupling is not ideal if I ever need to do any other work in this area.
    I like the threaded plug idea - I could match the thread type for the pump plug and then the connector for the LQ could work in either spot.
    Where do you find a patch for a 2" pipe? I've seen a shark bite thing at HD but that was for smaller pipes. Making one sounds easy enough actually - any specific kind of rubber to use for the gasket?
    Thanks all!
    May 2011
    lebanon tn
    370
    pretty much any rubber will do- if it is 2 in pipe, you can make a patch with a 6-8 in long 2 1/2 in pipe, line with 1/8 - 1/4 in thick rubber... (I'd use 1/8 in, wrap around pipe twice, then clamp 2 halves of 2 1/2 in pipe around it...)
