Thread: Does the volume of CL in the LQ matter?
    Dec 2010
    San Diego, CA
    1,137
    Does the volume of the CL in the LQ change the concentration on the CL being delivered? I have an 8 gal LQ and today decided I was tired of refilling it every two weeks with 2 gals (for maybe 3 gals max in there) and I went and got two cases of CL and put 4 gals in on top of the 2ish gals that were already there. Didn't touch my flow settings and tonight my CL was up 4 pts which means the pool got about a 1/2 gal of 12.5% CL! I was running at about a -.5 ppm per day CL rate with where my LQ was set so this was a huge reversal.
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: Does the volume of CL in the LQ matter?
    I think you have to leave some room for pool water to mix with the CL in the liquidator.
    Love TFP? Become a
    TFP Supporter!
    22,550
    It doesn't make a huge difference but it does make a difference when the level gets fairly low. I would refill mine whenever it got down to about 2 gallons and never noticed a difference in the amount of FC added to the pool.
    Dec 2010
    San Diego, CA
    1,137
    Zea3, I was still well below the line where the funnel meets the tube so I think I'm fine. But more CL does mean less water so that would affect dilution right?
    Dec 2010
    San Diego, CA
    1,137
    Thanks Bama. I do think I was letting it get too low before; hence the stock up
