Thread: opening pump
    Apr 2010
    Central Illinois
    205
    opening pump
    We tried to clean out pump strainer basket, but water gushed everywhere when we took the lid off!!! Did we forget to do something? BTW, the pump wasn't running.
    Thanks
    15x30x54 AquaLeader Sentinelle AGP
    2 HP 2 Speed Hayward SwimPro Voyager Pump
    Hayward SwimPro Voyager 150 sq. ft. Filter
    Hayward H series millivolt 150 btu Heater
    TF-100
    Re: opening pump
    If the pump is below the water level, as it almost always is with an above ground pool, you need to close off the skimmer and return, especially the skimmer, before opening up the pump. Often there are valves for the purpose. If you don't have valves, you can rig something, like putting a tennis ball in the skimmer, to block enough of the water flow to allow you to clean out the strainer basket.
    May 2011
    lebanon tn
    370
    Re: opening pump
    My skimmer came with a gizmo that screws into the bottom and blocks water... don't know how standard, never needed one before!
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    May 2011
    Berea. KY
    34
    Re: opening pump
    Hello, in the filter where the pump connects there should be a check valve that only opens in one direction(with the pump on). these check valves should be replaced every 2-3 years. Second if your filter doesn't have a check valve, make sure your multi-port valve is closed. winterized postion(i think) whichever position keeps the drains and returns closed. Hope this helps.
    Cole Pocius
    15'x30'x52" AG, 1 HP Hayward Power Flo, Hayward per-flex D.E filter, Aqua luminator. chlorine, baracuda beta. vinyl liner, 12,500 k gallon
