Thread: Adding Clhorine with Polaris .....
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    I need to add a 128 oz jug of bleach to the pool according to our test from yesterday. I also need to run my Polaris because we are getting acorns in the pool from the dang tree I want to take down but havent had time to do it
    My question is, can I add the bleach while the Polaris is running and will that be enough water movement to mix it or should I add the bleach first and then run the Polaris. OR canI add the bleach to the skimmer basket and let it run through the filter. I am waiting on the durn leaf net we orded to get here so I can cover the pool (I had to send other one back they sent wrong size)
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    I would add the bleach in front of a return, wait a few minutes, and then start the polaris.
    ETA of course, I may or may not know what I am talking about!!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    30,432
    Add the bleach to the skimmer....pump running......or distruibute it evenly around the pool, whichever you prefer. Put the Polaris in anytime.
    Do not count on the Polaris to circulate and mix the bleach.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    OK, my Polaris runs off of the only return that I have in the pool. Is it still ok to add it through the skimmer or should I just add the bleach and attatch the Polaris later?
    Les
    Helpful Links:
    30,432
    Either way. The higher concentration of chlorine will pass thru your Polaris very quickly. To be 100% safe you could let the water run for 15 min or so and then hook up the Polaris.
