Buying my first pool here and going to be doing a DIY install, and figured getting it right the first time is best... so are wall foam, liner pads and/or foam coping worth the couple hundred they cost?
Does wall foam keep the water noticeable warmer? Does it protect the liner walls better?
Do floor liner pads keep the water noticeable warmer? Do they protect the liner floor better? Do they provide a better looking bottom to walk on?
Is foam coving a lot easier to install than sand or dirt coving? Does it protect the liner better?
If you think it is worth it, is there any brand that is better or easier to use? and Where would you get it at?
