Thread: New pool owner needs start up help
    Why Easy Touch would shut off the pump?
    Does anyone know why Easy Touch would shut off the pump?
    Not sure if I'm posting this to the proper Forum, but here goes. I started up my pump (Pentair Water Syst) and everything seems to be working well. Good flow, etc. But after a few hours the Easy Touch system has turned the pump off. Any suggestions?
    Re: New pool owner needs start up help
    That depends on how the EasyTouch is programmed. Turning the pump on and off is one of it's jobs. Check the schedule in the ET to see when it is programmed to turn the pump on and off.
    Checked the Schedule and nothing was programmed.
