CYA question
dickeystorm
143
Lake Jackson, TX
My CYA is running high, 100+, so I am prepping for a drain refill soon once I get some equipment problems sorted out. I had a discussion with a pool store clerk, hence posing the question here, where he stated that the CYA was mostly at the top of the water and that I should therefore pump the water from the top of the pool when trying to lower CYA. So, is this pool store babble or is there anything to it? I have not seen anything like that on the forum.
On a related note, I notice a lot of people having trouble reading the CYA when it's over the 100 mark on the tube, myself included. The scale is logaritmic so it's not an easy read. Sorry if that is obvious to most, I just hadn't seen any cautions regarding guestamating numbers over the 100 mark.
most test kits don't even have readings over 100, so 100 really means 100+ AND no way of knowing how much +++++
If your pool is circulating, pump/filter online, then the CYA is fairly well mixed- add water opposite side and top/bottom from where you fill if doing at same time; if not, drain what you can (don't overdo the draining, can cause other problems!) then fill and recirc a few hours before testing again!
Once it is mixed in, CYA is very throughly spread throughout the water and stays that way. It does not accumulate more at one depth than at any other.
Don't try to guess the level over 100 based on a standard test. You will be way off. What you can do is to do the test with dilution. Mix equal parts of pool water and tap water together, measure the CYA level of that, and multiply the result by two. The results will be less precise, but they will give you an idea if your CYA level really is around 100, or more like 200+.
It is, in fact
pool store babble
Disregard it.
I wouldn't even attempt to interpret anything over 100 on the CYA test. rather make a 50/50 pool water/tap water solution and multiply the results by two. It's not very accurate, but it will give you a rough idea.
