Thread: Continually get debris in Jandy Aquapure 1400
    We have a Jandy Aquapure 1400, in floor pop-up cleaning system, and cartridge filter. The past few months we are continually getting debris caught in the salt cell causing an error message. What could be wrong with the system that is allowing debris to get in? Pool is about 5 years old. Thanks for any help.
    20K gal, spa, pebble IG, Pentair cartridge, Jandy aqualink 1400, Paramount in-floor
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Continually get debris in Jandy Aquapure 1400
    There shouldn't be any debris getting past your filter, so checking the cartridge to make sure it's seated properly and doesn't have any tears would be my first suggestion. What kind of junk are you pulling out of the cell?
    Leaves and stems. Debris normally caught in the skimmer or leaf basket (or whatever that is called). Thanks.
    Oct 2009
    3,899
    Definitely a filter problem.
