Thread: SWG and switch length?
    Diver's Avatar
    May 2011
    South of Boston
    450
    what is the combined length of the typical SWG and the switch together? does the generator require straight pipe right before the unit?
    i'm going to do some plumbing and i want to have a straight section where i could later put SWG, so i'm trying to figure out minimum length for that run.
    thanks!
    26K In-ground Vinyl Pool | Hayward DE4820/SP0710XR50 filter | 1.125 HP Dual Speed Hayward Super Pump | Aquasol Solar
    Re: SWG and switch length?
    It varies quite a bit from brand to brand. If you have two feet of straight pipe you should be set for just about any of them.
    Diver's Avatar
    May 2011
    South of Boston
    450
    thanks, Jason
