Results 1 to 9 of 9
Thread: Clean and Clear Plus, D.E. media required?
    Oct 2010
    Eastern TN
    172
    I just started up my new Clean and Clear and while reading the manual noted that it recommends DE media .75lb/100 sq.ft. to be added at startup. Needless to say, I don't have any available. A few questions. Is it a problem to add it in a few days? Was starting it w/o the media a big mistake? Does Walmart usually carry this?
    Dave
    Plaster pool inground 22,000 gallons with spa. Pentair Intelliflo, IC40 salt generator, WiFi control/Easy Touch.
    Hayward 1.5 HP pump on 750 gallon spa. Sand filters. Auto chlorinator on spa. Auto water level. Dolphin M500. TF100 XL with Speed Stir. Apera Instruments AI311 PH60 Premium Waterproof pH Pocket Tester
    Re: Clean and Clear Plus, D.E. media required?
    It will be fine even if you never add the DE. You should only add DE when the cartridge is clean, and only once (until you replace the cartridge).
    Mar 2011
    Central Florida
    69
    I just set up my Clean and Clear (not plus) as well and saw on the box that it said "DE Element Filter" and not "cartridge filter." However, I was unable to find any info in the manual about adding DE being required or optional.
    EDIT- The way I worded this post it sounds as though I was presenting information contradicting the concern of the OP. In reality, I was seconding the concerns of the OP. I was puzzled as to why the box said "DE Element Filter" for a cartridge filter and why there was no mention of DE anywhere in the manual. Any ideas?
    8,700 gallon IG pool (including 2000 gallon spill-over spa), WetEdge Northshore Tahoe (Satin Matrix) finish, Hayward SwimPure Plus T-15, Jandy JXi 260k propane heater, Jandy FloPro 1.5HP 2 speed pump, Jandy CS 150 cartridge filter, TF-100, Borates added, BBB is the way for me!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I have never seen DE at Walmart, however at least around here Lowes sells it in 20 pound boxes for around $20 give or take.
    Ike
    Oct 2010
    Eastern TN
    172
    None at my Lowes in NC.
    You may have just seen the new combined box for EasyClean/Clean and Clear. Pentair does this on a lot of boxes. They have a universal box, and the placement of the box label indicates the model. If the label is in the "Clean and Clean" box, its a cartridge filter. If its in the EasyClean box its a DE Element filter.
    There is no need to add DE to a cartridge filter on startup. It can't hurt to get the water really clean on startup, but it is not required.
    In-ground Filters Engineer
    Pentair Water Pool and Spa, Inc.
    www.pentairpool.com
    1620 Hawkins Ave
    Sanford, NC 27330
    Mar 2011
    Houston, Texas
    413
    That's odd in that the OP's manual and my manual say to add some DE upon initial start up.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    You can add DE as explained in the manual, it just isn't required (and most people don't).
    Oct 2010
    Eastern TN
    172
    Quote Originally Posted by BriceJohnson
    Brice,
    This is a bit confusing. The instruction manual for my Clean and Clear Plus states the following on page 4:
    For first time operation on new pools introduce into the system .75 pounds of diatomaceous earth per every
    100 square feet of filter area (a one-pound coffee can equals .5 pounds of diatomaceous earth). Mix the diatomite
    with water and pour it into the skimmer after the pump is primed and the system is operating. This will enhance
    the filtration of your water
    I added it last night. The pool has not been used but the filter has been running for a week. I'm assuming that my cartridges were still "clean". Had to but a 25lb bag. Any TPP forum members nearby are welcome to a few pounds...
