Thread: Black smoke coming from heater
    May 2009
    Greenwood, Indiana
    25
    I opened our pool today...it was perfectly clear! I attribute that to this forum and the BBB Method. Even the heater started right up. The only thing new this year was that when I fired up the heater (Hayward H200), I noticed black smoke coming out of the vents. I shut of the heater, waited 15 minutes and turned it on again. Black smoke again. The smoke has left soot on the vents. The water temperature is only 55F. Any ideas what the problem could be?
    Strom
    16 x 32 Inground Vinyl, Infinity 2000 Automatic Cover
    Hayward S210T 2.2 sq ft Sand Filter with 1 HP Speck Badu EcoM3V Pump, Hayward H200 Heater
    Dolphin DX4 w/remote, CircuPool RJ-30 SWG, Taylor K-2006, SpeedStir, Borates, Zeosand
    Re: Black smoke coming from heater
    It could be some sort of debris that has gotten into the heater. Possibly from animals building nests.
    There could some sort of problem with the gas/air mixture causing incomplete combustion. Possibly improper gas pressure or blocked airflow. Gas pressure might be low due to a partially closed valve.
    The heater will have to be thoroughly checked and cleaned before being used. It should be left off until it can be repaired.
    Support the site
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    353
    There is a spider called...what else..."orifice spider"! They love to get into the venturi sections of gas appliances and disrupt air flow. Black smoke is a sign of incomplete combustion from insufficient air. It's too early for dirt daubers.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
