Thread: New Pool PH rising fast
    Jan 2011
    Austin, TX
    30
    We have a 19K gallon SW pool with grey plaster. Our 2 month old pool requires a quart of muriatic acid every 2 to 3 days in order to keep the PH balanced. I know that new pools require acid to keep balanced but this seems like quite alot.
    Is a gallon of acid a week a reasonable amount? When can I expect this to slow down? I have been told that SW pools always require acid is this true?
    Thanks in advance.
    BlueBell
    Austin, TX
    19K gallons, 500 approx sq. ft. pool, 33' x 16', outdoor, inground, med. grey plaster interior, gunite, hayward tristar 1 speed pump, perimeter 95
    Re: New Pool PH rising fast
    That amount of acid is only a little high for 2 month old plaster. Fresh plaster requires a lot of acid for the first three or four weeks, and some acid for up to a year.
    Some of the acid demand might be from other things. If you post a full set of water test results we might spot something that you could adjust to get the acid demand down.
    Jan 2011
    Austin, TX
    30
    FC 2
    CC 0
    PH 7.4
    hardness 245
    T/A 50
    CYA 80
    Salt 3300.
    Temp 75
    Thanks
    BlueBell
    Austin, TX
    Your numbers actually look quite good. The acid demand must be mostly coming from the plaster. I would adjust the FC level up a little, 2 is fairly low with CYA at 80.
    Jan 2011
    Austin, TX
    30
    Thanks alot. I guess I just wanted some reassurance that we weren't doing something drastically wrong.
    I really appreciate this site and all the help.
    Thanks again.
    BlueBell
    Austin, TX
