Results 1 to 8 of 8
Thread: water evaporation vs leak
    rwrogers11's Avatar
    Apr 2011
    Katy, Tx
    66
    What should I expect to see in evaporation here in SE Texas? Right now I'm losing about 1" of water per week. I've crawled all around the plumbing, checked everything and cant find any leaks. We are in a drought right now, so I'm not sure how much the weather is affecting the loss of water.
    Richard
    Pool - 18' Doughboy Above Ground Vinyl, 7600 Gallons, 1HP Hayward Power-Flo Matrix pump, Hayward Star Clear Cartridge Filter C500 50 GPM flow rate, Hasa Chlorine Injector, Pool Rover Vacuum, Taylor K-2005 Testkit - Hot Tub - Artesian Pelican Bay, 550 Gallons, Ozone, Nature 2 Mineral Sanatizer, Bromine floater.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: water evaporation vs leak
    1" a week is not uncommon and pretty average for most areas. I can lose over 2" per week in the summer without the solar cover on.
    Mark
    Aug 2010
    Dallas, TX
    4,052
    You can do a bucket test to determine which it is, but yea here in Dallas 1" a week is not only common, but I've seen worse than that in the real heat of the summer.
    rwrogers11's Avatar
    Apr 2011
    Katy, Tx
    66
    Hmm, havent thought about a bucket test, but I'll do that this week, and measure the drop on both. Thanks for that idea.
    Richard
    Mar 2007
    San Rafael, CA USA
    12,082
    Note that from the Pool School article on Leak Detection that the bucket of water should sit in the pool water so that it is at the same temperature. Specifically,
    ...fill a bucket with water, mark the level of the water in the bucket, set it on the stairs and compare the water loss between the pool level and the bucket level.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Thanks Richard
    Luv& Luk
    -Ted
    Aug 2010
    Bryant AR
    16
    error delete
    Aug 2010
    Bryant AR
    16
    Not kidding there are weeks in the summer I put in water 2-3 times and watch 2-3 inches evaporate. I thought maybe I had a leak but all our Friends pools had the same thing. Also my pool has no shade so if the sun is up at 6:30 it is shining on it until 7pm or later when it dips behind the neighbors trees.
    Ask people in your area what there water loss is.
