Results 1 to 17 of 17
Thread: My conversion has started
    Jun 2010
    Northern Half of New York
    12
    I think this is my first post on TFP. I've been reading since last year after our pool company started our new pool on Baquacil. After a summer of paying for that stuff I decided to do some research and found out it's quite a project to convert so I stuck with it through the end of the season and just started the conversion now in the spring. Thanks for all the good reading material.
    21' x 48" Above ground partially buried Aqua Wood 10,000 gallons. Thanks TFP for the information to convert from Baquacil to BBB.
    May 2011
    lebanon tn
    370
    Re: My conversion has started
    Once you're thru the process, I'm sure you'll be happy with it!
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    Welcome to TFP!
    Wonderful pictures. If you have any questions, feel free to ask. And we always love to see pictures
    Jun 2010
    12
    Quick question, I literally dumped the chlorine in, came inside downloaded the 4 pictures I took, posted it and went back out and check my FC. It was already down below 3, or at least never got anywhere near 15. So questions, how long between adding chlorine and testing for free chlorine? Next, in the beginning like this how quickly is normal for re-dosing? Thanks
    Tim
    Jun 2010
    12
    OK so I shot from the hip, punched my numbers into the pool calculator and added more chlorine. Now I've got my FC up to 13.5 with my TC at 17. Guess I'll poke a little more bleach in there.
    It is good to wait an hour or more between chlorine additions and the next cycle of testing and adding chlorine. Right at the very beginning you could probably go a little faster if you wanted to.
    Jun 2010
    12
    So I am 6 hours into my conversion, I have used 8.3 gallons of chlorine so far and I am already going from green to blue kind of I'll get a picture in the morning, it's probably too dark now. I'm not having any signs of the sand filter plugging, I've been backwashing it every hour or so since there were a bunch of dead bugs in the water anyways.
    I added my last dose of chlorine and went and mowed the front lawn, an hour later my son and I checked the FC and it was at 15 still. I might have added a little extra chlorine last time My son wanted to make some water turn colors so for the heck of it we did a CYA test, the water never changed color at all. I am assuming that is normal? Should I adjust the other chemistries before the conversion is complete? I know the conversion instructions say to wait until the end but it is helpful to pick the CYA up? Thanks
    You definitely do not want to add CYA right now. That would dramatically slow down the conversion process. The only number other than FC and CC that matters much at all during the conversion is PH, which you should only adjust when the FC level is down near zero and shouldn't change to much through the process. PH should be between 7.2 and 7.4 when FC is 2 or lower.
    Jun 2010
    12
    This morning the pool is looking great! After last checking the FC at 9:10pm I checked it this morning and it was down to 5 ppm with a CC of 2 ppm.
    Wonderful progress!
    You are already moving into the second phase of the conversion. At this point you will be losing more chlorine to sunlight than to the conversion. You have a choice, to either move the conversion along as quickly as possible by continuing to add chlorine every hour, or to save a lot of chlorine but take a bit longer by only adding chlorine in the evenings.
    Jun 2010
    12
    Only lost about 5 ppm of FC last night, we went from a tad over 15 down to 10 and the CC was .5. The CC number has been below 1 since yesterday. Since starting the conversion on Friday afternoon I have gone through just shy of 17 gallons of bleach.
    The pool is only 61 degrees so I don't think you'll see me in there anytime soon but the conversion is going great.
    That is great! Another day or two or three and you will pass the overnight FC loss test and be ready to replace the filter media and add CYA.
    May 2011
    lebanon tn
    370
    My pool was 66 yesterday- not bad, but not ideal for swimming- I jumped in with the kids, for a short bit; they stayed in about an hour!
    Jun 2010
    12
    My Mad Chemist at work!
    Jun 2010
    12
    Finally got to clean out my filter today, it was pretty gross but not from the Baquacil conversion, more from the cottonwood fuzzies flying around and getting through the strainers. See below
    I added CYA and baking soda my numbers are as follows:
    FC: 4
    TC: 4
    CC: 0
    pH: 7.5
    TA: 70
    CH: 120
    CYA: 40
    Congratulations!
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    I'm glad your conversion went so well The inside of that filter is disgusting Hopefully, that was an easy cleanup project!
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
