Thread: Water Temperature Sensor
    With a little too much time on my hands, I was thinking about automating solar heat collection for the pool. I've browsed a bit, including this thread:
    diy-automated-controls-advice-solicited-t5708-80.html
    In putting together a parts list, I know I'm going to need to add a water temperature sensor
    http://www.amazon.com/PENTAIR-WATER-POO ... B001DO18FS
    and I just wanted to get a reality check:
    So I'm supposed to drill into a perfectly good piece of PVC, and the O-ring and clamp are going to hold the thermistor against a curved piece of pipe, right? Somehow, I'd feel better if I could find a flat section, but I'm trying to get my mind around how this is supposed to work.
    18000 gallon in- ground fiberglass pool.
    Hayward DE filter, solar heat in sunny San Jose, CA.
    Automatic pool cover.
    Re: Water Temperature Sensor
    Yes, that is the way they are designed to be installed.
    Photos and updates at the end of next week. Planning on automating a loop with pump run and solar heating for the pool.
