Results 1 to 10 of 10
Thread: Pool Calculator for Android OS
    Jul 2010
    Central Illinois
    40
    Has anyone dl'd the one from the android market and tried it? Is it reliable like the one found here?
    18' x 54" Round AGP, Hayward pump/Cartridge Filter, 8 Gallon Liquidator, and TF-Test
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Re: Pool Calculator for Android OS
    bit pricey
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    I've tried out the one from Green Brook Software. Their older version was extremely limited, but the February update added most of the essentials. I find their user interface annoying and they are missing some obvious things like the muriatic acid concentration (they just assume 20 Baume) and the cal-hypo concentration (not clear what they assume), but it seems to work.
    Ft Lauderdale, Florida
    1,455
    I just bookmarked www.poolcalculator.com on my droid and it seems to work correctly. Not through the App store.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Feb 2011
    Sicklerville, NJ
    80
    Quote Originally Posted by Poolsean
    I just bookmarked http://www.poolcalculator.com on my droid and it seems to work correctly. Not through the App store.
    Wasn't the web supposed to universalize everything so it didn't matter what kind of device we had? Why are we going backwards having to install an app for everything OK, rant over, in case it wasn't apparent I'm seconding Poolsean to bookmark poolcalculator.com
    25k gal Lazy-L, vinyl liner, poly walls, swimout spa, diving board, TurboTwister slide.
    Hayward 2HP 2-spd pump, Pentair 2HP spa pump, Hayward 30" 500lb sand filter.
    Goldline Pro Logic PS-8 automation/SWG. 2 LED ColorLogic 4.0. 8 Jandy deck jets. MX-8 cleaner.
    Jul 2010
    Central Illinois
    40
    I did the same as you sean, just curious about it is all!
    I sent the pool calculator guys an email and told em to quick making things for silly iPhones before they did one for Android. hehehe.
    Batavia, IL
    28
    I'd but an android version.
    20 x 45 Inground vinyl, ~34,500 gallons,
    4 returns, 2 skimmers, dual main drain
    Pentair EasyTouch 4, IC40 SWG, MiniMaxNT 400, TR100 sand filter,
    Whisperflo .34/2 hp 2 speed, Polaris 280 w/ polaris booster pump,
    Wild ride slide, InterFab techni spring base w/ 8' InterFab olympian board
    APC 365 dark gray auto cover
    Mar 2011
    441
    Quote Originally Posted by tinkerhell
    People using androids should be smart enough to use their web browser to find it. Needing a special app is for iPhone users.
    20X40 30,000 gallon gunite pool
    Sep 2009
    Greentown, IN
    914
    Yes, iphone users have to pay for most of their apps... why not just use the site online
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
