Results 1 to 7 of 7
Thread: foam coves and gorilla pad
    Apr 2011
    Ohio
    97
    I am still trying to figure out everything, before we have a pool installed. I want the foam cove, and the gorilla pad seems good. I would like to know that no rocks will work themselves up, and that there would be less chance to have deformities in the bottom (like foot impressions)
    So, how should I expect the installer to install these? (they don't sell gorilla pad, only foam pads. I plan to buy elsewhere, but they said they will install it) Obviously the sand is laid out. Now, the questions:
    1) do they build ANY kind of cove with the sand, or make it completely flat, all the way to the wall of the pool, and the foam is the only raised area? I ask, because when I looked, they show pics of it both ways: http://www.aquasupercenter.com/produ...Cove~3061.html
    2) Does the gorilla pad lay down first, then cove on top, or cove first, then pad sitting up on the cove?
    14.6K gal., 24ft, 54" above ground. 2HP, 2speed Hayward pump (4psi low, 18psi hi), 150sqft cartridge filter. 4x20 solar panel (6 psi).
    ultra800_96's Avatar
    May 2009
    Pomeroy, Iowa
    225
    Re: foam coves and gorilla pad
    Quote Originally Posted by Drayken
    On my pool, the gorilla pad (mine was called happy bottom) went down first, then the cove on top of that (no sand). I also opted for wall foam (thin foam pad just like the bottom). I feel it really helps keep heat in the pool overnight & an added benefit is cushioning the liner from the steel wall. That was 16 years ago, so maybe things have changed, but it still works for me.
    12,900 Gal. 24' X 48" ABG Vinyl Round (17th Birthday)
    1HP Hayward Pump w/S180T Hayward Sand Filter
    AquaTrol RJ SWCG 2011 startup
    TFP Method since '09, TF100
    50ppm Borates, June '12
    22,548
    The pad goes down first then the cove on top of that. I have the same thing and no sand.
    Apr 2011
    Ohio
    97
    Thanks. That is what I assumed. Now, you both did NOT use sand. Any feelings on that? I don't like the idea of losing more water depth from using sand, and the pad. Maybe 1 inch to make it all perfectly level, then the pad?
    22,548
    Mine doesn't have any sand at all, but then again, our soil is pretty sandy so they just leveled it really well and put the pad right on the dirt. I think it would feel better if it had a little but of sand under it but I really don't know.
    Apr 2011
    Ohio
    97
    Hey, by the way. Advise please: I am thinking of "jamming" in a 24ft pool, lol. A 21 will fit easily, but for only $200, I can get the 24ft. The excavator said to measure out a 30ft circle, and judge to see if I am ok with how close the pool will be to some pine trees. (I have to fit it between a row of pines, and a retaining wall that I will be building, which is by my septic system. I plan to have the wall about 3-4 ft from the edge of the septic tank.)
    Is 30ft a little more than needed? I see most people with a foot around their pools. (backfill, when installed) 27ft and I am fine, but it is TIGHT with 30ft.
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Another option is instead of or in addition to the gorilla pad, 2" styrofoam. Helps insulate and protect the bottom of the pool. I learned about it from a friend that has a 24' AGP and has had the styrofoam in for about 10 years now. I have been using it for about 6 years.
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
