Thread: Free chlorine is around 25
    After I shocked the pool. I believe I put twice the amount of shock I was supposed to. Is this a big problem?
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    Re: Free chlorine is around 25
    That depends on what your CYA level is. You should always post a full set of water test results with questions like this one. It might also help if you kept this together with one of your other topics, so we could see the context of what was happening recently (which can affect things).
    CYA is at 20. Rest of my results are on the other computer. Do I need to do something about the FC?
    Bel Air, MD 21015
    With CYA around 20, the FC will be far lower by tomorrow afternoon from the sunlight. Given that you have a plaster pool you should be fine at that FC level for 12-16 hours.
    Does it matter if I have a solar cover? Should I take it off?
    Bel Air, MD 21015
    I would take the solar cover off. You want the FC level to come down, since you are at about twice shock level, and the cover might interfere with that.
