Thread: Heater wont light
    Heater wont light
    Early '90's Teledyne-Larrs natural gas heater, 400000 btu with electronic ignition. It clicks, then stops and then I smell gas. I also noticed a while back that the heater had a hum (24 volt transformer?), if that has anything to do with it. I'm thinking replacing all the electronic ignition, but I would like your opinion. Thanks, Jerry
    L-shaped 36'6"x18' by 10'10" x 12'2", 27K In-ground Vinyl Pool | Hayward Pro-Grid DE4820 filter | 1.125 HP Dual Speed Hayward Super Pump | Borated
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Heater wont light
    Jerry, welcome to TFP!!
    If you are qualified to do this (if not get the gas guy out there ) check the burner end of the gas line to see if a spider built it's web there/ or if something else is clogging the outlet.
    Was the gas line disconnected from the heater over the winter (which could possibly allow water to enter and block the line)?
    Luv& Luk
    -Ted
    Ted, thanks for the reply. I took the air compressor and blew out the burner area. It still wont light. Any other ideas?
    Mar 2007
    4,160
    I'd say call you gas provider. This isn't an area where non-professionals should tinker with it, there's just too much of a chance for BAD things to happen!
    Luv& Luk
    -Ted
    May 2011
    lebanon tn
    370
    look inside while the clicking is going on- is there actually a spark? sometimes the piezo electric circuit is out of whack, and the clicking noise doesn't mean sparks are actually occuring...
    also, the safety is supposed to prevent excessive accumalation of gas without ignition- if you're smelling gas, especially after a few seconds the gas smell continues, shut off the gas valve and get a gas mechanic in there soon!
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
