Thread: Filter leaking
    WestSidePool's Avatar
    Cincinnati, OH
    424
    Filter leaking
    I just started my pool up tonight for the season.
    When i went back to check on the pressure at my filter i noticed water around the base of it. I saw it was dripping between the top and bottom portion where the metal belt has splits. I took it apart and inspected the unit and belt and saw nothing damaged. I put everything back together and made sure the belt was tightened to spec.
    I turned everything back on and still have 1 leak at one of the belt splits.
    Any suggestions?
    It's a Hayward DE4820
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    Re: Filter leaking
    You need to closely examine the gasket that seals the top and bottom and make sure it is clean and free of nicks or cuts and that the two surfaces it mates with are clean and free of gouges. Then apply some silicone lube to the gasket and seal it back up again.
    Cincinnati, OH
    424
    Re: Filter leaking
    Thanks for the tip, i'll give it a try.
    Just to be clear. Is this the type of stuff I want to get?
    Eric
    Apr 2009
    New York, Texas
    26
    Re: Filter leaking
    I have found that turning the gasket over (top to bottom) every time I clean usually prevents leaks ...
    40K gal rectangular IG Gunite ... white plaster ... 20 ft negative edge ... 2 Intelliflo VF 3050 pumps ... 2 Sta-Rite Cartridge filters ... IC60 SWG ... Pentair Thermaflo heat pump
    Re: Filter leaking
    The silicone spray is not the type of stuff you want to put on the gasket. There are tubes of gasket/o-ring lubricant sold at pool supply stores that you should use. Jack's Magic is one brand. Leslie's also has a house brand. The cost is about $5.00 to $7.00 a tube. Put a little on any rubber o-rings or gaskets whenever you take a valve or connection apart. Once a year or so on the o-ring in the strainer basket helps prolong the life of that gasket. Gently clean the gasket and make sure there is no debris on it before putting the lubricant on it.
    Chris
    19,000 vinyl pool, solar heat, .75 hp tristar, 48 sq ft de filter
    Cincinnati, OH
    424
    Re: Filter leaking
    Quote Originally Posted by jack@eztrakr.com
    This worked for me. Thanks
    Eric
