Results 1 to 16 of 16
Thread: Years of pucks got me here...Help! New results!
    Please help me face the music:
    FC 4.8
    Ph 7.8
    TA 210
    CH 210
    CYA 100+ is MUCH higher. Lost the black dot in 1/4" of solution.
    Have struggled with low ph for years. Now I know why. Adding chems...adding pucks. Have stripped my liner of color on the floor of pool.
    Finally took control this year. Added SWG mainly because everyone told me it caused Ph to trend up.
    Still added over 100lbs. of washing soda/borax to get ph to 7.6 to 7.8.
    Wrong move I see now.
    Pool calculator says I need to replace 53% of my pool water.
    What do ya'll think?
    BTW K-2006 arrived 10 mins. ago.
    In case it doesn't show on sig. 33K vinyl, Large Hayward sand filter, 1 1/2 hp Super pump. Pentair ic-40 SWG
    33,000 gal vinyl
    Pentair IC-40 SWG
    Hayward sand
    1 1/2 Hayward Super pump
    Full sun
    Re: Years of pucks got me here...Help!
    Oh, btw CC 0
    33,000 gal vinyl
    Pentair IC-40 SWG
    Hayward sand
    Full sun
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Yes, unfortunately its do a partial drain/refill before you begin to rebalance. Be sure to test again after allowing the new water to thoroughly mix. you may need to repeat.
    Can you recommend a procedure?
    Surely I don't drain 1/2 the pool at one time.
    33,000 gal vinyl
    Pentair IC-40 SWG
    Hayward sand
    Full sun
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,625
    Just don't drain it MORE than 1/2 at a time. The increments are up to you. 1/2 water swap is a good place to start. No telling what your TRUE CYA level is. Then retest.
    11,969
    As long as you leave at least 1-2 feet of water in the shallow end it should be fine, it really depends on your local water table (and restrictions with regard to draining). Its safe for almost all pools to drain down 1/3.
    While I have the water low, might as well take advantage.
    My white fiberglass steps are stained...well kind of orange pink.
    Any ideas as to what caused it and how to clean?
    Thank you.
    33,000 gal vinyl
    Pentair IC-40 SWG
    Hayward sand
    Full sun
    One more quick question.
    Is this water gonna damage plants and landscape?
    Bad enough I let my kids swim in it, hate to kill my yard, too!
    33,000 gal vinyl
    Pentair IC-40 SWG
    Hayward sand
    Full sun
    Ottawa, ON, Canada
    153
    Can you grain it in the sanitary sewer?
    19.5k gallons in ground, P4 panel with turbocell SWG, 1hp Hayward superpump II, sand filter, Heater low nox 250k btu heater, solar cover on rocky roller
    22,551
    Just draining it on the ground won't hurt anything. I drain pool water on the grass all the time. and there is a poster here that uses the pool to feed a sprinkler system.
    Try a Magic Eraser on the steps. And if that doesn't work try a spot using half diluted bleach. Both of those things are ok to be in the pool.
    Once you have it drained and refilled, circulate it all for about an hour then test the CYA again before you adjust anything else. That'll tell you whether you need to drain/refill again. No use wasting chems if you have to do it again. You only want to get the CYA down to about 80 since you have an swcg and are in full sun.
    Thanks everyone. My pool has a large L shaped shallow end, so I don't think I can change 1/2 the water at a time.
    I took the water down to 1 1/2 feet in the shallow and am re-filling now. Will probably take a couple days to complete.
    I will post my new numbers ASAP.
    Thanks again for everyone's help. Great forum!
    -Mark
    33,000 gal vinyl
    Pentair IC-40 SWG
    Hayward sand
    Full sun
    After 2 water changes, one 40% and then another 50%:
    FC 1.8
    CC .2
    PH 7.8
    TA 100
    CH 80
    CYA 100 maybe a smidge over
    So there is little doubt that my CYA was over 200. To be honest, I am less than thrilled with doing another 20% water change. I think I will ride this for a bit.
    What challenges can I expect while managing a high TA and CYA?
    I am going to construct a return vent aerator as shown in the forum to lower the TA slowly. If I read correctly, I will need to lower ph significantly to do so. Correct?
    I have replaced the salt and will turn the SWG up tomorrow.
    How did I do?
    33,000 gal vinyl
    Pentair IC-40 SWG
    Hayward sand
    Full sun
    Apr 2009
    Central Minnesota
    74
    When you have one number off the charts, such as you do with CYA, dilute your test sample with a known ratio of distilled water. Get a reading and multiply by your ratio. That way you know what to do ahead of time instead of draining random amounts of water and refilling.
    18' X 36' X 4.5' vinyl oval in-ground 17K gallons, 250K BTU Pentair Master Temp NG heater, 1HP Hayward Super Pump, Hayward S200 sand filter, Hayward Pool Vac, Extreme mesh safety cover, TF-100 test kit.
    Re: Years of pucks got me here...Help! New results!
    Your TA won't be a problem. 100 is only a little high. Just lower the PH to 7.2 any time it gets up to 7.8 and the TA will come down over time.
    The CYA level is going to be more of a challenge. Even with a SWG you need to keep FC at 5 or higher all the time. That probably means targeting 6 or 7 to be sure it never goes below 5. If you get algae, things will be very challenging until you lower CYA further.
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by Ground Loop
    ... I think I will ride this for a bit.
    I don't think you'll have any problem IF you keep your FC up high where it belongs with a high CYA level.
    Last year was my first full year with the TF-100 test kit. Because I had the TF-100, I knew from the start that my CYA was about 90. I opened late and didn't have time to do a partial drain & refill. I had to get my FC up wicked high to shock the pool & kill the opening algae. Because I had the TF-100, I could get an accurate TC/FC measurement and could measure "wicked high" numbers, like 45 or 50 ppm. My PH was high, too, at 7.8-8.0.
    A high CYA really buffers the chlorine and it took a while for my FC to drift down to the low teens, even with lots of direct sun & high heat. Then, I maintained the FC in the 10-15 range. After reading about maintaining pools at high PH levels, I also left the PH in the 7.8-8.0 range. I had clear, sparkly water for the rest of the season.
    Frankly, it seemed that I had fewer Cl excursions, especially to the low side, than in previous years. But, I'm no Chem Geek, so I don't have any rational explanation for that.
    So, YMMV, but I found that I was able to manage a high CYA level. Not the optimum situation, but you could give it a go.
    Good luck!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Thanks everyone.
    I am going to change the water later in the year. I need to give my water bill a break.
    Maybe change it during the hottest part of summer and give the pool a refreshing chill.
    Thanks again for everyone's input. Make a big splash!
    Mark
    33,000 gal vinyl
    Pentair IC-40 SWG
    Hayward sand
    Full sun
