Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Calcium Chloride..
    Calcium Chloride..
    I need to raise my calcium hardness. Anyone know where I can get Calcium Chloride from other than a pool store..
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Calcium Chloride..
    Quote Originally Posted by precator
    Well, Howard just found some with free shipping from Ace Hardware. It is being shipped to the store for him to pick up.
    post254318.html#p254318
    HTH
    You're done SLAMing when:
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Home Depot sells it too.
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    Quote Originally Posted by benavidescj
    what is it called at Home Depot?
    Bel Air, MD 21015
    Butterfly's Avatar
    South Carolina
    10,045
    Depending on your location, you may or may not find it locally. Be sure to call before you drive!
    From Pool School:
    Calcium hardness can be raised with calcium chloride or calcium chloride dihydrate. They are available in some areas as Peladow, Dowflake, Tetra Flake, or Tetra 94, often sold as a deicer by hardware stores, and some big box stores, in colder climates. Pool stores will carry either calcium chloride or calcium chloride dihydrate under a variety of names, including Hardness Plus, Balance Pak 300, Calcium Hardness Increaser, etc. Calcium products should be spread across the surface of the deep end of the pool
    Mar 2007
    San Rafael, CA USA
    12,082
    [EDIT] See the post after this one. The Home Depot product to get is really pool time Calcium Hardness Increaser.
    I'm moving a discussion I had about DampRid to a separate thread on that product which may have too much iron in it for use in pools.[END-EDIT]
    Apr 2010
    Fleming Island, FL
    431
    It's called Pool Time Calcium Hardness Increaser. Like Butterfly said you may want to check to see if your local store has it before driving.
    Carlos
    Can I use RoadRunner Ice Melt as a way to add in Calcium Chloride?
    Here is a product page here http://www.icesalt.com/product-revie...nner-ice-melt/
    It is advertised: "is a combination of powerful compounds that include salt, potassium chloride, magnesium chloride, and calcium chloride."
    Would the other ingredients be by-products that I would not want? (I do have salt water).
    BTW, I can get this product for $3 for a 10lb bag right now.
    16' x 48" Intex Metal Frame Pool - Round (5,100 gallon)
    Intex Salt Water Generator w/800 GPH pump.
    I wouldn't use Ice Melt. It isn't pure calcium chlorine, so you will need more, and it contains magnesium, which could get to levels high enough to cause stains.
    Thanks for the reply...
    I'll do some searching to find the other products that contain Calcium Chloride.
    Update - Looks like Home Depot has the above mentioned product in stock in my local store!
    http://www.homedepot.com/Outdoors-Ou...atalogId=10053
    Aug 2010
    Dallas, TX
    4,052
    Chlorinating with Cal Hypo will do it.
    solarboy's Avatar
    Aug 2010
    Europe
    337
    Quote Originally Posted by RobbieH
    That's what I'd do, kill 2 birds with one stone so to speak.
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    I've done that before, it takes a LONG time to get an increase of 50 ppm or so. On the other hand, if you need CH and also need to shock, cal-hypo would do the trick quite nicely.
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    Jul 2014
    Chapel Hill, NC
    40
    Is pool time calcium hardness increaser calcium chloride or calcium chloride dihydrate?
    30,000 gal IG pool, vinyl liner, Hayward Superpump 1 HP, Hayward S244S sand filter, Zodiac LM2-24 SWG, Polaris 280 TankTrax cleaner, TF-100 and Taylor K-1776 test kits
    Jul 2015
    Cedar Rapids, Iowa
    4
    Quote Originally Posted by precator View Post
    Prestone Driveway Heat or equivilant. No cheapie blends, the 18.00 for 50lb stuff.
    30,431
    This thread is over a year old and probably is not of much interest to anyone.
    Apr 2015
    Tulsa, Oklahoma
    48
    I bought calcium chloride on Gemplers online. Just showed up today. Took about 5 days.
    Jun 2010
    Richmond, Virginia
    12
    Actually, Duraleigh, it is of interest to me right now
    Pool size: 30,000 gallons
    Filter: Sand, Triton II TR-100
    Filtration flow rate: 74 gpm
    Pool: IG
    Type: Plaster
    Pump: Emerson, 2HP
    Jul 2017
    Colorado
    86
    Quote Originally Posted by vagrowr View Post
    And to me now! Our local stores have plenty of 100% calcium chloride de-icer but zero pool calcium. Now I know I can use the good de-icer.
  20. Back To Top    #20
    And to me! Thank you TFP, for keeping threads like this open so we don't have to post a new thread!
    39,000 gal 48 x 22 gunite/pebble, SWG
    Pentair Intelliflo
    Jandy Aqualink RS; Jandy 60 DE Filter
    Polaris 280 Black "Manta Baby"
    3 Jandy WaterColors LEDs
