Thread: Where could I plumb a bleach pump?
    Feb 2011
    Central Texas
    187
    I am looking at my pad and I do not have enough pipe to add a pump. Any suggestions are appreciated:
    IG 23K Gal, Quad DE 80, PebbleSheen, Intelliflo VS+SVRS, MT 400 NG, Stenner Pump
    22,553
    Re: Where could I plumb a bleach pump?
    Plumb it after the "T" below the valve past the chlorinator. In the pool return. It only takes a 1/4" NPT fitting tapped into the pipe.
    Voodoo_Pool's Avatar
    May 2011
    On the border AR/TN
    82
    What about adding a tap fitting to the cap on the CHLORINATOR? Would that not work also? I ask this because I have a FROG system that is empty and I am thinking about adding a bleach pump (STENNER). What sort of bleach pump do you intend to use? Thanks.
    IG Vinyl 27,000 gallon "L" shaped (new vinyl April 2018) with spillway spa; Hayward 4820 DE; Polaris 380 w/ booster; TF-100 Test Kit w/SpeedStir
    Quote Originally Posted by Voodoo_Pool
    That would be extremely dangerous and could result in an explosion. Never mix two different forms of chlorine together. Add them to the pool separately.
    Feb 2011
    Central Texas
    187
    So, I am getting ready to install. I really wish I had room to cut the elbow after the inline and before the valve and replace with a tee. Then I could use a FNPT adapter there. I just don't think there is enough pipe above that valve to do that.
    Other options:
    A. In the pipe just before the elbow
    B. into the elbow itself
    C. Below the valve, but in the tee fitting. Below that is really close to ground level, and I still have not back-filled the pump area with pebbles yet.
    Thoughts on the best location?
    22,553
    Either the pipe before the elbow or the elbow itself is fine. Either will drill and tap.
