Thread: Help with building Outdoor Island
    Guest
    Firstly, I am amazed at all the great looking outdoor BBQs and Islands that members are making here. Wow!!
    I am new to the whole pool and outdoor bbq stuff.
    We moved to a new home recently (in Toronto) and I have tons of questions.
    We are planning to get a pool built later this year or early this year as we are still waiting on grading and exterior work to be completed on the home. I'll post in the pool section on question for the build.
    As for the outdoor Island / BBQ, I like the look of the stone walls and stone counter.
    How does one go about starting to learn how to build one? I am fairly handy so just need some reading material and guidance.
    What material are required? I see metal studs, hardiboard, etc. Where can these be bought from? Don't think Home Depot carries metal studs (I could be wrong and probably am...). Any books / resources online that would should a step by step build including materials to get?
    Thanks!
    Voodoo_Pool's Avatar
    May 2011
    On the border AR/TN
    82
    Re: Help with building Outdoor Island
    Try this on for size: http://www.thisoldhouse.com/toh/how-to/ ... 84,00.html
    Maybe this one: http://www.diynetwork.com/topics/outdoo ... index.html
    Here you go: http://www.hgtv.com/home-improvement/ho ... index.html
    My experience is that if Home Depot does not have it, then Lowe's will. Do you have Lowe's in Canada?
    Be sure to share photos of the finished project. Good luck!
    IG Vinyl 27,000 gallon "L" shaped (new vinyl April 2018) with spillway spa; Hayward 4820 DE; Polaris 380 w/ booster; TF-100 Test Kit w/SpeedStir
    Guest
    Quote Originally Posted by Voodoo_Pool
    Great! Thanks!!
    Apr 2011
    Warner Robins, GA
    245
    Lowes and Home Depot both have books on Outdoor kitchens. They are fairly easy to build, witht he most cost on the appliances, and the counter tops. An alternative I have used before is to use concrete block for the frame, not metal. Its easy to work with AND inexpensive. I then faced it with flagstone.
    16 x 32 Grecian Vinyl. Salt-Aqua Plus PS-4, Hayward Pro Series Sand Filter, Hayward Ecostar SP34000vsp, Gulfstream HE-125-T-A Heat/Cool heat Pump
    May 2011
    lebanon tn
    370
    I use a lot of wood framing...
    if your handy, a lot of grill vendors and NG/LP companies have lots of nice layouts- but probably won't share plans; just a good place to get ideas!
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
