Results 1 to 10 of 10
Thread: Pool guy told me to shock the pool..
    So I did a test and saw my FC was only at .6 ppm. So I went to the pool calculator found out how much bleach I needed and added that. That is the same as "shocking" the pool correct.
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    Re: Pool guy told me to shock the pool..
    No, you should read the instructions on shocking in Pool School.
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    No, shocking is raising the level of FC up to the shock level for your CYA level. If you go to this link you will see what the shock level is for different CYA levels. I believe that Pool Calculator is giving you the Target FC which is also shown on these charts. Target FC is what you use if you do not have algae. Shock level is what you use if you do.
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    Quote Originally Posted by benavidescj
    I don't have any green algae. Just my FC is really low..
    Bel Air, MD 21015
    You don't have to shock unless FC goes to zero, or CC is higher than 0.5, or there are obvious signs of algae (cloudy green water for example).
    MY cc was higher than .5. So I would need to shock correct? Last night my FC was at .6. So I put in like 200 oz. of bleach in a 32k gallon pool. I am assuming that wouldn't do too much since I needed to shock the pool correct? I would probably need closer to 3 x that amount correct?
    Bel Air, MD 21015
    Yes, if CC is above 0.5 you should shock.
    How much chlorine you need to add depends on your CYA level.
    22,551
    Post a full set of the latest test results. We appear to be jumping around here without a full picture of what's going on.
    pH
    FC
    CC
    TA
    CH
    CYA
    Will do that tonight when I get home from work
    Bel Air, MD 21015
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Excellent Also, you can use www.poolcalculator.com to calculate how much bleach is needed to raise FC.
    In general, 1gal of 6% bleach will raise FC by 6ppm in a 10k gal pool. So in your pool (32k gal) you would need about 3 gallons to raise your FC by 6ppm. The 200oz (about 1.5gals) you added should have bee good for about 3ppm...which is not much if your CC was above 0.5.
