Thread: Robot Cleaners Advice, parts, service etc
    Isaac-1's Avatar
    SW Louisiana
    6,711
    After years of using suction side cleaners with mixed results (my latest somewhat pricey model gets caught on the steps) I am considering the purchase of a robotic cleaner. I keep seeing horror stories about repair problems, lack of replacement parts, requirement to send off to expensive repair centers for simple repairs, etc. So I wanted to ask, which brand is the most do it yourself repair friendly, and which model would work best in my application with an indoor pool where most of the cleaning needs are for dirt and small debris (bugs, etc).
    thanks Ike
    p.s. do you have any thoughts on the cheaper robots like the Orion / Orion II, etc
    Re: Robot Cleaners Advice, parts, service etc
    Aquabot No 1 1996 to 2008, Could have been repaired when drive motor died.
    Aquabot No 2 2008 to present - No problems
    Only needed to replace belts and scrubbers over they years.
    Pool: 30,000 gal concrete with 600 gal Spa, 1.5 HP Pump (2.0 max), Citadel III 400,000 BTU gas heater, Apollo 52 SF DE Filter. (All equipment OEM Anthony Pools circa 1980 from Pentair), Aquabot.
    Pond: 2500 gal, 3/4 HP Hayward Max Flow, Hayward Star Clear 750 Prefilter, Emperor Aquatics BioPro Filter, Tetra UV Light.
    Dec 2009
    Central Massachusetts
    2,690
    I have an Aquabot Turbo I like.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
