Results 1 to 11 of 11
Thread: How Long to stay at Shock Level
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Like the subject says, After the FC and CC have stayed constant during overnight tests how long should i stay at shock level? Another day just to be safe? 48 hours for me at shock level, all is good? Seems like it should have taken longer but this morning all was the same. Tomorrow will be the for sure test if it still is good. Then do I let it go one more night? Also should I just leave the SWG off for a few days to burn down?
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Re: How Long to stay at Shock Level
    There are three criteria to be done shocking:
    CC is 0.5 or lower;
    An overnight FC loss test shows a loss of 1.0 ppm or less;
    And the water is clear.
    Yes, when done shocking you might as well leave the SWG off for a couple of days until the FC level comes down.
    Voodoo_Pool's Avatar
    May 2011
    On the border AR/TN
    82
    Don't forget to give it a good brushing...the pool...and your teeth.
    IG Vinyl 27,000 gallon "L" shaped (new vinyl April 2018) with spillway spa; Hayward 4820 DE; Polaris 380 w/ booster; TF-100 Test Kit w/SpeedStir
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Voodoo, brushing two times a day. Teeth too!
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Ok Shocking process is done! Wasn't that bad, about 48 hours and the water was clear and passing the overnight tests. Most of my algae spots are gone, been brushing 2-3 times a day, regular and ss brushes on the spots. Picking up some rust (I think) spots now have to deal with this later. I have kept the pool at shock level for the last 5 days just to be sure. Water is even better looking now! I'd thought it already was crystal clear. Tested this morning and here are the results:
    FC 26
    CC 0
    TC 26
    PH 7.5
    CYA 85
    TA 130 (when it turned yellow, not sure how accurate this is at this level)
    Added some extra MA to lower the PH so I can aerate to lower the TA some more. Dosing pump is still not working and I can't figure out why?
    I would like to start adding Borates next but I need to lower TA a little more.
    May 2011
    lebanon tn
    370
    sounds like you're on track! now it's swimtime- the rest will be easy over time...
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    The TA test is still valid at high FC levels.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Thanks Jason! A level of around 80 TA is needed for Borate addition correct?
    Not required, just nice. It is easier to lower TA before you add borates, but you can lower TA after you add borates if you want.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Ok Jason, I got time I think I will lower it now. I got a smoking deal on Borates but I only got 13 boxes! So I have to wait until I get all of what I need (26) before I add Borates.
    May 2011
    lebanon tn
    370
    You can add the borates in increments- you don't have to wait for the whole bang, just slowly add what you have and add more later...
