Thread: Easiest Pool Opening Ever?
    GTA Ontario
    43
    This was my first season opening the pool. We moved into the house last Aug and had a little over a month to enjoy the pool before I had it professionally closed in October.
    I was ready to call the pros back in to open it but since I'm a hands on type of person I thought I'd give it a shot myself.
    Opening Day -2
    The pool is irregular shaped and has a snap in vinyl cover. We had quite a bit of snow and rain so the cover had approx 3' of water on it. I used the leaf rake to take off most of the leaves that had collected along with the dead rodent that was floating in there . I tossed in a sump pump and within a few hours all I had left was a few inches of water here and there on the cover.
    Opening Day -1
    I ran two garden hoses out to the pool and topped it up before I took the cover off. My rational was that I knew I'd be pulling the cover off solo, so why not get it a little closed to the top of the pool to make it easier to drag out. After 4 hours it was topped-up.
    Opening Day!
    Rain
    Opening Day Redux!
    I threw the sump pump back in and collected the few inches of water that had collected due to the rain. Replaced all the drain plugs in the heater, pump and sand filter. Cover was dry and I snapped it off in about 20 mins and dragged it out. There was some debris in the pool, mostly leaves and dirt but the water was fairly clear. It's still cold 8c or 46deg so algae hasn't had a chance to form I guess. I removed the plugs from the pool and replaced the summer hardware and fired up the pump. No problems so I scrubbed, raked and vacuumed then backwashed. I tossed in 4 bags of salt before I took any measurements. I probably should have measured first but figured I'd likely need to add a few bags so I went conservative with 4 bags.
    I don 't have a proper test kit yet so I took visited the local pool store for a test.
    Here are the results - I was totally shocked at the numbers, as were the ladies that tested the water. The couldn't believe that I'd just opened the pool earlier today;
    FC- 3ppm
    TA - 90ppm
    pH - 7.2
    CH - 210
    CYA - 10ppm
    Salt - 3500ppm
    Outside of adding some stabilizer I'm pretty much ready to rock!!! Is it normal to have numbers so good on day 1?
    40,000L (10,500G) 17 x 30 Pioneer "Trinity" Vinyl IG
    Hayward OmniLogic, Hayward TCELL925-CUL SWG, Hayward SP23520VSP MaxFlo Pump, Club Pro SM2506T Sand Filter, Hayward H-Series Heater, Zodiac G3 Cleaner.
    Mar 2009
    Charlotte, NC
    539
    Re: Easiest Pool Opening Ever?
    What is the CC?
    Yes you can have good #'s opening if you close right, do winter tests (& treatments if needed), probably some luck, etc.
    I opened this yr & didn't need to shock- very cool
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
