Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Concrete
    Concrete
    I am thinking about fixing the concrete around my pool. Currently, it has sagged in a few areas and is an inch or so away from the lip of the pool as well. It looks like the pools last owner just put concrete patch between the old concrete and the lip of the pool to prevent water from getting in between.
    I am thinking of hiring someone to raise the contrete so it is level with the lip of the pool, and then using a concrete paint enhance the look. Does anyone have any experience with repairing concrete around pools?
    16 x 38 inground pool, 20K gal, vinyl liner, 0.75 HP Hayward Superpump (SF 1.0, 115 V), Hayward Pro Serier Top Mount 24" sand filter (300lbs sand) with 62GPM design flow fate and 3.1 sq ft effective filtration area, Kreepy Krawly cleaner
    CincyRed's Avatar
    Jul 2010
    Orlando, FL
    61
    Re: Concrete
    I saw a show once where they repaired a sidewalk that was uneven with, I think it was called, mudjacking. They drill holes through the sunken concrete slab, then pump grout into the holes until the slab is level, then patch the hole. You might want to check into that. Good Luck!
    15,000 gallon in ground free form pool (500 sq ft) with waterfall, 4x160 Intelliflo Pump, IntelliChlor IC40,
    Rheem Heat Pump with cooling, Cartridge Filter, Quartz WhiteGem Finish, Auto leveler, Pavers.
    My Pool Build
    Feb 2011
    Sicklerville, NJ
    80
    Re: Concrete
    Quote Originally Posted by CincyRed
    Not sure that would work around a pool. The pool wall could be jacked out before the deck was jacked up! Maybe if the wall was braced beforehand? Dunno, just make sure whoever does it has good insurance
    25k gal Lazy-L, vinyl liner, poly walls, swimout spa, diving board, TurboTwister slide.
    Hayward 2HP 2-spd pump, Pentair 2HP spa pump, Hayward 30" 500lb sand filter.
    Goldline Pro Logic PS-8 automation/SWG. 2 LED ColorLogic 4.0. 8 Jandy deck jets. MX-8 cleaner.
    CincyRed's Avatar
    Jul 2010
    Orlando, FL
    61
    Re: Concrete
    Quote Originally Posted by MajorDIYer
    After your post MajorDIYer I have to admit I never thought of that aspect, so I searched to see if anyone is doing it and found this company.
    http://www.pooldeckleveling.com/
    So it might be worth checking out.
    Of course also making sure the company has good insurance.
    My Pool Build
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: Concrete
    They specifically state it wont work with liner pools. 10-20PSI can add up QUICK!
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    CincyRed's Avatar
    Jul 2010
    Orlando, FL
    61
    Re: Concrete
    Quote Originally Posted by Lershac
    I don't know what I am missing (could be a lot), but they specifically state that they work on vinyl liner pools. Just not with expanding polyurethane foam.
    My Pool Build
    ConcreteJack's Avatar
    May 2011
    Williamsburg, VA
    42
    Re: Concrete
    Hello, my name's Kirk Roberts, and I'm a project manager with Concrete Jack, the company with the PoolDeckLeveling.com website. Our process, which is called slabjacking, mudjacking, concrete leveling and various other things, depending on where you live, works quite well on all types of pools; vinyl-lined, drop-in fiberglass and concrete. We do use two different materials, one of which, expanding polyurethane foam, is only used around concrete and drop-in fiberglass pools. We use a soil based grout material for around vinyl-lined pools (the foam is injected as a liquid, and if the seams between the vinyl-lined pool panels aren't sealed well, it can get between the panels and expand, which would cause problems). The grout is course and dry enough (injected at a consistency between hummus and peanut butter) that this doesn't happen.
    Though there aren't many photos of vinyl-lined pools on our website, but we do up to five of them a week, all over Virginia and North Carolina. In response to the comments about pressure, pool walls are much stronger than concrete; we routinely lift slabs around vinyl pools that don't have any water in them, though it is preferable to have the pool full during work, and also use the material to void fill under and around fiberglass steps which are bouncy. If you have indications of a fundamental failure of the pool wall, such as bowing walls, it would be best to empty the pool, pull the liner and check out the wall before attempting concrete leveling. We work quite frequently around all kinds of structures that are much more fragile than pools.
    Voids around pool decks are one of the most common causes of floating liners, as surface water from precipitation or irrigation runs under the deck, through the seams in the pool wall and gets between the pool wall and liner, causing the liner to float (ground water can do the same thing). It is quite common to find up to 2 foot voids under the concrete decking surrounding vinyl-lined pools. The concrete leveling process works by filling the voids with the injected material (foam or grout), and then after the voids are filled continuing to inject material, which displaces the concrete up. Our video page, http://www.concretejack.com/viewvideo/3 ... -animation, shows an animation of the process at work.
    Here's a link to the page with before and after photos of concrete pools where we have lifted the concrete:
    http://www.concretejack.com/pool-decks/ ... ter-photos
    Here's a link to the page with before and after photos of vinyl pools where we have lifted the concrete:
    http://www.concretejack.com/vinyl-pools
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: Concrete
    wow, impressive!
    May 2011
    Williamsburg, VA
    42
    Re: Concrete
    To find a contractor that does this type of work, search on Google for any of the following terms (try all of them, because there's lots of regional variation in what our types of contractors call themselves):
    mudjacking
    slabjacking
    concrete leveling
    pressure grouting
    slab raising
    concrete raising
    Additionally, if you search for any of those terms on YouTube, you can see it in action.
    Feb 2011
    Sicklerville, NJ
    80
    Re: Concrete
    Well there you go. Thanks for sharing your knowledge on this subject Kirk. I'd still be a bit nervous if it were being done to my pool, but being a little more educated now I wouldn't hesitate to consider it.
    May 2011
    Williamsburg, VA
    42
    Re: Concrete
    Yeah, we were nervous on our first couple We're located in an area where tons of people have pools so we work on lots of them, but in places where pools are less common, it wouldn't be surprising to find concrete leveling contractors that were more cautious about taking on jobs around pools; they can look (and sometimes be) quite intimidating!
    However, slabjacking/concrete leveling is a great process for correcting trip hazards and helping to prevent floating liner problems on pools. In general it costs about 1/2 the price of demo and repour, the customer can walk on everything immediately and it doesn't leave big areas of mis-matched concrete.
    Re: Concrete
    I wanted to see what you all though about the concrete around my pool. I have kind of a weird trim on my pool and I am not sure if the concrete was meant to come up flush with it or if it was meant to have some sort of a silicon cocking (I am sure I am not spelling that right) or ground in between the pool trim and the concrete. I attached a variety of pictures from different areas around the pool. It looks like the old owner of the pool simply used a grout to bridge the expanse between the pool trim and the concrete apron
    Re: Concrete
    Here are a few more pictures
    May 2011
    Williamsburg, VA
    42
    Re: Concrete
    I've only seen that type of pool once (rather old style, not sure what it was called), but the process did work. I don't have original photos for you to compare to, but the ones attached are marked up for one of our crews that did the work on the pool. The notes convey a little bit more detail about the joint between the coping and the pool deck, and the red arrow points to the gap that opened up between the bottom edge of the coping and the top of the concrete.
    The biggest thing to watch for would be underpour, or if the deck concrete was poured to be under the coping. Someone has filled the joint between the concrete and the bottom of the outside edge of the coping with some sort of caulk; if the concrete is lifted with that in place, it was push up the coping; whatever's in that joint would need to be completely removed before attempting lifting. The sketch shows this; as you can see, the concrete extends up towards the back of the pool wall, under the outside edge of the coping. You'll be left with the jump marked with the red arrow (from the pictures, the back edge of the coping looks like a finished edge and not one that used to be covered in concrete).
    Looks like it would work, though my guess is that the coping always sat on top of the deck, so lifting would minimize the height of the jump from the top of the concrete to the top of the coping, but it probably wouldn't work to achieve a level transition between the two surfaces.
    May 2011
    Williamsburg, VA
    42
    Re: Concrete
    This photo is a little cross section; you can see the coping in the bottom right corner of the photo above where the coping is resting on top of the deck in the areas where the deck had not settled.
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    Re: Concrete
    ConcreteJack, where it says "Hampton off of Mercury" is that Hampton, Va off of Mercury Blvd? I live in Chesapeake.
    14,700 gal. 14 x 28 rectangle with 2R IG by Hydra Pools, 1 hp Hayward Maxflow ll, Hayward 24" Sand Filter, Aquarite Electronic SWG, one Aqua Genie Complete Skimmer, two main drains, four returns, 2 spa jets in steps, 30ml Tidewater liner. Taylor K-2006 Test Kit
    Re: Concrete
    I see what you are saying about the removing the caulking first.
    But I do think that the coping and the concrete can be level with one another. There is actually a few spots around the pool where they are even, but that is the excepiton. At those points where the concrete are level with the coping, I wonder if there should be a small gap that needs to be filled with something (caulk or grout).
    May 2011
    Williamsburg, VA
    42
    Re: Concrete
    Do you have a photo of that area?
    Re: Concrete
    Here you go
  20. Back To Top    #20
    Re: Concrete
    I had a guy over today that said he would not touch my pool. He took one short look and left. I tried to tell him that there were other companies that did this type of thing. I honestly don't think they were even listening to the words coming out of my mouth. I don't know what I am going to do now. I don't want to have to rip everything out.
