Results 1 to 8 of 8
Thread: How to Install rail over the steps?
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    Just bought a new Pool! Came with a house!
    The pool has no rails over the stepdown. What is the procedure for installing the rails.
    Concrete Cantileaver deck Inground pool.
    14x30 PebbleTec(Caribbean Blue) 12,000 Gals BORAX
    Pentair IntelliFlo <<>> Pentair FNS Plus DE
    Pentair 5G Intellibrite w/Intellibrite Controller
    ROME Solarium 125 Heat Pump
    Kreepy Krauly Classic <<>> Pentair 320 Feeder
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Re: How to Install rail over the steps?
    Hey les_garten,
    Welcome to TFP. I can't answer your question, but I'm sure someone will come along a help you out.
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    Quote Originally Posted by orthofish
    Hey les_garten,
    Thanx!
    This is a Forumus Awesomus!
    Rails normally mount to the same kind of deck anchors that ladders mount to. Typically a large core drill is used to drill holes in the deck and anchors are then cemented in place in the holes. It is a little tricky if you use metal rails on an existing pool deck, since then the anchor needs to be bonded (electrically connected to the bonding system with #8 bare copper wire) so you have to find somewhere to wire the anchors to.
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    Glad I posted thgis here.
    I was reading some posts in the builders thread. I noticed this bonding stuff. That's why I decided to post. I was thinking up till then, it was drill a few holes and that would be it.
    This sounds practically inpossible to do correctly/safely without a ton of expense.
    You can, but it is annoying. You cut a slot from the anchor to somewhere else and push the wire down into it. The main challenge is figuring out where you can get a good connection to the bonding system.
    South Central NJ
    3,192
    Another option is to use plastic sockets and rails. Saftron make them.
    Scott
    Owner of - PoolGuyNJ LLC
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    Quote Originally Posted by PoolGuyNJ
    Scott
    Thanx! This looks interesting!
