Thread: Kreepy Krauly
    Apr 2010
    Southern California
    83
    Kreepy Krauly
    I don't remember ever having this issue last season, but about a week ago I got out the Kreepy Krauly out for the first time in quite a few months and it will not stay on the pool floor at all. I tried pushing it to the bottom with a pole hoping it would catch the bottom with suction and stay there, but it just lift back off the bottom after a minute and then just floats around suspended in the water and does nothing to clean the bottom. Is there something I can try to fix this? Thanks
    12,000 gallon IG (newly re-plastered) pool, Pentair 3/4hp pump, DE filter, TF-100 test kit
    22,553
    Re: Kreepy Krauly
    Sounds like it has an air bubble trapped in it somewhere. I know on my Ranger, it'll do that and I have to turn it up and shake the bubble loose.
    Apr 2010
    Southern California
    83
    Re: Kreepy Krauly
    I'll try that, thanks
    gullzway's Avatar
    Nov 2009
    Tulsa,OK
    103
    Re: Kreepy Krauly
    Make sure the 3 blue ring weights are in the right spots on the hose. Also do you put your hose in front of a return to blow all the air out before hooking it to your suction source?
    17,500 gallon 18x36 gunite pool
    Hayward super II 1.5 hp pump, Hayward cartridge filter
    Jandy AquaPure Ei SWG 35K, Raypak R6350TI-E HeatPump
    Solar cover, Loop Lok winter Cover
    Artisian Antigua hot tub, Polk Atrium 4's
    Apr 2010
    Southern California
    83
    Re: Kreepy Krauly
    I never thought of putting the hose in front of a return. I'll try that.
    Also, I did not know about the blue right weights, so that is probably a factor as well. Thanks!
