Thread: Chlorinators
    Chlorinators
    Does anyone have any advice on pool chlorinators. My little floating deal with chlorine tabs just does not do the trick. I was thinking about an offline chlorinator by Hayward.
    Due to my setup, I can't use an inline. I just don't want to invest in something that others have found to not work well.
    16 x 38 inground pool, 20K gal, vinyl liner, 0.75 HP Hayward Superpump (SF 1.0, 115 V), Hayward Pro Serier Top Mount 24" sand filter (300lbs sand) with 62GPM design flow fate and 3.1 sq ft effective filtration area, Kreepy Krawly cleaner
    Voodoo_Pool's Avatar
    May 2011
    On the border AR/TN
    82
    Re: Chlorinators
    I find that I am the best CHLORINATOR. Nothing better than going out to the pool, testing it, and adding the correct chemicals in the correct amount. Having said that, do you want automation? Are you not able to add chlorine manually every day or at least on a regular basis?
    The LIQUIDATOR seems to be a good product, if not a bit quirky at times. What about a dosing pump? BAMA RAMBLER seems to be the newest convert to a dosing pump.
    I'll stick with the manual dosing, myself...for what it is worth.
    IG Vinyl 27,000 gallon "L" shaped (new vinyl April 2018) with spillway spa; Hayward 4820 DE; Polaris 380 w/ booster; TF-100 Test Kit w/SpeedStir
    Re: Chlorinators
    I did a lot of adding liquid chlorine last year. I would like automation. I would like to leave for a few days and not have to worry. I would like to have the pool covered for a few days when we are not using it and then not have to go out and check it.
    Re: Chlorinators
    A SWG would be a better choice, though it does cost more up front.
    Re: Chlorinators
    How often do you have to run the pool with something like the liquidator to make sure enough chlorine gets into the pool. Do pumps have to be run all day?
    Re: Chlorinators
    The Liquidator is usually fine with 4 to 6 hours (or more) of pump run time, though it does vary quite a bit higher and lower depending on several details of your setup.
