Results 1 to 9 of 9
Thread: Gallons in pool
    Gallons in pool
    If my pool is roughly 20 x 42. min depth 3 feet max depth 8. Would my approximate gallons be 35k?
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    May 2011
    lebanon tn
    370
    Re: Gallons in pool
    I get just over 36k- but could vary a lot based on how much is at 3 ft, how much at 8, how steep the slope...
    35k probably a good place to start for poolcalc!
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    22,550
    Re: Gallons in pool
    I get just shy of 32,000 gallons. A few chem additions should help you narrow it down.
    Re: Gallons in pool
    I'd guess closer to 31k. Of course I'm just guessing.
    Re: Gallons in pool
    I guess I can find out once I start doing my chemicals,etc. I have been running my filter for 2 days straight now. I am guessing now is a good time to do a water test and start adding chemicals correct?
    Bel Air, MD 21015
    Re: Gallons in pool
    Oh yea. Unless the plaster is brand new, 2 days is kind of long to wait.
    If the plaster is new, just put perhaps three trichlor tablets in the skimmer(s). If it isn't brand new, do a full set of water tests.
    May 2011
    lebanon tn
    370
    Re: Gallons in pool
    I got lazy on my calculation, remembered 8 gal / cu ft, (it 8 lb/gal, 7.5 gal / cu ft)
    so my number was a little high...
    Voodoo_Pool's Avatar
    May 2011
    On the border AR/TN
    82
    Re: Gallons in pool
    I would caution against putting trichlor tablets in the skimmer(s) unless you run the pump constantly until the tablets are dissolved. If you shut off the pump with undissolved tablet remaining, the tablet will continue to dissolve and you will have a 'slug' of chemical going through your system when the pump is turned back 'on'. Not a big deal if done once or twice...but over time this can cause damage. I recommend getting a floater as a 'safer' option and for use when you go on vacation...or "Holiday" for our European readers.
    IG Vinyl 27,000 gallon "L" shaped (new vinyl April 2018) with spillway spa; Hayward 4820 DE; Polaris 380 w/ booster; TF-100 Test Kit w/SpeedStir
    Re: Gallons in pool
    Voodoo_Pool, on a brand new plaster pool you need to run the pump 24/7 anyway, so there is no problem. Trichlor in the skimmer for a couple of weeks has all kinds of advantages for brand new plaster. As you point out, not such a good idea otherwise.
