Thread: Solar Heating?
    Solar Heating?
    Anyone aware of performance and maintenance differences between Fafco and Heliocol solar panels? From the sales pitches I heard, they use different size pipe, installation on tile roof varies, one purportedly has a cleaner look (less pipe on roof), Fafco recommends 7 panels, Heliocol 6. Panel installation on east facing exposure-two story.
    Appreciate any feedback offered.
    NPG
    Sacramento CA area,
    420sgft inground
    14,00 gal, salt water
    Pentair 230v VS pump
    22,542
    Re: Solar Heating?
    You won't go wrong with either of those brands. The Fafco's are a little more efficient according to the Florida solar energy dept but they're both close.
    Nov 2009
    Indialantic, FL
    323
    Re: Solar Heating?
    +1
    You might be able to fit more Heliocol panels up because they are slightly narrower, but they are also slightly longer, so...Not sure why you got quoted less Heliocol.
    But if it's not a space issue, the same number of panels will result in approximately the same efficiency. So if you got quoted the same price for Fafco as Heliocol, you will get more band for the buck with more Fafco panels (to the tune of however much heat one panel produces).
    Panels & Pipes in my area can be sourced in the same size (2") from both companies.
    Heliocol doesn't use mid-panel straps so they don't have as many roof penetrations (places to leak). I also like that Heliocol doesn't use the strap clamps on hoses between panels.
    Replacement parts for Fafco seem to be somewhat available on the Internet, not so for Heliocol. Last time I looked anyway - this might depend on the warranty length, and how long you think you will be there, but it's something to consider.
    Geometric 16X36', 16K gal, shotcrete, exposed aggregate plaster, acrylic coated concrete deck/cantilever coping;
    Pentair equipment suite (EasyTouch w/wireless, 2 Intellibrites, Intelliflo VS-3050, C&C 200 Filter, IC-40 SWG);
    Heliocol solar panels, Rocky's Roller, Blue Diamond robot
    Re: Solar Heating?
    Bama Rambler and Dave J, thanks for the response.
