Results 1 to 11 of 11
Thread: Measuring DE
    Measuring DE
    I see that I am supposed to put in like 2.4 lbs of DE. If I use a regular like cooking measure, is this equivalent to 38.4 ounces ?
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    Mar 2010
    Spring, TX
    1,082
    Re: Measuring DE
    I would not be able to help you there. What I do is have a small scale and then put a cup on the scale. Notice the weight of the cup empty and then pour in what I need to make the weight go the appropriate weight.
    Just looked it up and you are right. 2.4 lbs=38.4 ounces
    Basically 2.4X16(Ounce in a Pound)=38.4
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Apr 2009
    Northeast Ohio
    221
    Re: Measuring DE
    I don't have a DE filter, but I would recommend measureing it out once into a container you can reuse. Then mark a line on the container and just fill it to that line in the future. Keep in mind that as JasonLion has said, you only need the full amount after cleaning the filter. After backwash you'll only need about 80% of that.
    (Mods, feel free to edit or delete if I didn't get that quite right.)
    -- Pete
    32x16 ft Grecian rectangular vinyl pool 8ft on deep end - 19000 gal. 18" Hayward S-240 sand filter. 250K BTU Pentair MasterTemp heater. Hayward 3/4 HP Super Pump.
    Re: Measuring DE
    DE is measured by weight. They do make special scoops that hold 1/2 lb of DE. Also, if you have a standard 1 lb coffee can, that is about 1/2 lb of DE, but that is a little less reliable as coffee cans vary a little bit.
    Voodoo_Pool's Avatar
    May 2011
    On the border AR/TN
    82
    Re: Measuring DE
    If you don't want to actually weigh the DE powder on a scale, then I recommend going to your local pool store and purchasing a BLUE SCOOP. It is calibrated. Also, unless you take the filter apart and completely clean the grids to remove ALL of the old DE, then you do not need to add the full amount of DE powder. Backwashing does NOT remove ALL of the old DE powder. I discovered this when I removed the top of my filter for the first time after purchasing the house. So much old DE powder (from previous owner) existed that it formed a reverse image of the lid. This was after I backwashed and saw clear water in the sight glass. How do your grids look?
    IG Vinyl 27,000 gallon "L" shaped (new vinyl April 2018) with spillway spa; Hayward 4820 DE; Polaris 380 w/ booster; TF-100 Test Kit w/SpeedStir
    Re: Measuring DE
    Quote Originally Posted by Voodoo_Pool
    I am too much of a novice to open up the filter. That will happen eventually in due time once I get more comfortable with everything..
    Bel Air, MD 21015
    May 2011
    On the border AR/TN
    82
    Re: Measuring DE
    No way! Take charge! Do you have the owner's manual? If not...GOOGLE it! It really is NOT that scarey to take the top off your filter. You may be surprised, as I was, and it could save you a lot of frustration in the future. If you are not comfortable, so be it. But think about it.
    Apr 2010
    Philadelphia, PA
    92
    Re: Measuring DE
    I have found that a 16oz Solo cup for drinking is a good way to measure DE.
    Doug
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Measuring DE
    Honestly Am I the only one who's read this :P
    Luv& Luk
    -Ted
    Re: Measuring DE
    Quote Originally Posted by precator
    1 gallon of DE is about 2.7 pounds.
    Support the site
    Re: Measuring DE
    My owner's manual tells me that 1/2 pound of DE fills a 13 oz coffee can. So 2.4 pounds would fill 4.8 x 13 oz coffee cans. If like me, you buy coffee in a 34.5 oz can, it would be 1.81 x 34.5 oz cans.
    18,500 IG vinyl lined
    hayward cartridge 120 sf
    1hp 2speed hayward pump
