Results 1 to 9 of 9
Thread: Recommended cleaning supplies
    I have an old manual vacuum cleaner as well as an old RAYVAC self cleaner. My question is do the new manual vacuum cleaners do a better job than the older ones. Is it worth replacing?
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    Apr 2009
    Northeast Ohio
    221
    Re: Recommended cleaning supplies
    Personally, I think as long as the manual vac is in good condition (any brushes in good condition or replaced, attacments not cracked), I would continue to use it. We inherited a Hayward SuperVac with our pool and used it without issue for five years. It finally got old enough that the plastic was cracking, so we replaced it this year. I don't know enough about the RayVac cleaners to say.
    -- Pete
    32x16 ft Grecian rectangular vinyl pool 8ft on deep end - 19000 gal. 18" Hayward S-240 sand filter. 250K BTU Pentair MasterTemp heater. Hayward 3/4 HP Super Pump.
    Quote Originally Posted by loughps
    -- Pete
    Do I need to get the "leaf trap" that I see in some videos...
    Bel Air, MD 21015
    Apr 2009
    Northeast Ohio
    221
    I don't have one for my manual vac, but I use a vac plate on top of my skimmer and attach my hose there. Any large material then gets trapped in the skimmer basket. But I've only had that for a couple of years, I used to just vac to waste. I don't think the leaf trap is something you "need", but if it makes your pool care easier, you may want to add one sometime.
    When there are a lot of leaves, I use a leaf bagger.
    I have like 5 - 10 leafs on the bottom of the pool. Some are of the larger variety. what is the best way to remove these...
    Bel Air, MD 21015
    With that few leaves, I would try to catch them in a leaf rake, and if that didn't work then just vacuum them up (and clean the basket right after).
    Voodoo_Pool's Avatar
    May 2011
    On the border AR/TN
    82
    A few leaves on the bottom...just jump in and grab them! I personally don't even use the manual vacuum head. Instead I simply swim around with a mask and vacuum hose to get up any dirt/debris that my Polaris "missed". It is fun, too!
    IG Vinyl 27,000 gallon "L" shaped (new vinyl April 2018) with spillway spa; Hayward 4820 DE; Polaris 380 w/ booster; TF-100 Test Kit w/SpeedStir
    Quote Originally Posted by Voodoo_Pool
    We just opened our pool, and we are in MD. Water is too **** cold for now! lol But in the summer sounds like an awesome idea!
    Bel Air, MD 21015
