Thread: A couple seriously newbie questions
    Oct 2010
    Temecula, CA
    122
    I have a skimmer/main drain diverter that, when I moved in, hung out in the skimmer. What is the purpose of this? Should the "door" on the bottom of it be opened or closed if used in skimmer.
    I also have what appears to be a "floating weir" that sits in my skimmer basket, rather than a door like you have listed in Pool School. What exactly is the point of this? Does it need to be there? It doesn't exactly keep the junk from floating back out of the skimmer as far as I can tell.
    Thanks for answering my questions.
    Anne
    Temecula, CA
    16X32 (approx) 20k gal, DE filter, IG, plaster/pebble with diving board & slide
    Whisperflo pump; Pentair SMBW 4000 Series filter... that's all I know! Still learning....
    22,539
    Re: A couple seriously newbie questions
    The diverter is used to adjust the flow between the skimmer and the main drain.
    The weir is to help the skimmer skim the top of the water more effectively. It also helps prevent the skimmer from creating a vortex and causing the air to sucked into the pump.
    Oct 2010
    Temecula, CA
    122
    Is there a reason I would want to divert the water from the skimmer to the main drain?
    Also does that diverter ever need to be sitting on top of the skimmer basket and weir for any reason?
    Thanks
    Temecula, CA
    Aug 2010
    Dallas, TX
    4,052
    I would like to be able to divert mine to 100% main drain when I'm sweeping the pool. I don't know if it's common practice, but it would help me to get everything to the drain and subsequently to the filter if the main drain had more pull during sweeping.
