Results 1 to 10 of 10
Thread: Salt vs chlorine
    Salt vs chlorine
    I had a pool In PA for 14 years and never had a problem keeping the pool clean. I moved to North Carolina and was told the only way to go is salt water. Is it hard keeping the pools clean with Chlorine in NC?
    22,553
    Re: Salt vs chlorine
    Welcome to TFP.
    If by clean you mean sanitized. It's no harder to keep a pool sanitized in one part of the country than in another. swcg's are a good way to do it but so is adding beach or a chlorine injection pump. It's all relative and it's only as hard as you think it is.
    SW Georgia
    300
    Not living in both places I would not know if one was harder than the other to keep a pool clean, but would guess the answer was no. SWG work fine and are the right choice for some. I keep mine clean with liquid chlorine. I test my pool daily so adding Chorine daily is just as easy for me.
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    30,432
    Nope, not a bit!
    [attachment=0:181oupw8]clear pool water.JPG[/attachment:181oupw8]
    Aug 2010
    Dallas, TX
    4,052
    I wish my robot would quit breaking!
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by pebblesboy
    A salt pool IS a chlorine pool. Chlorine is made from the Cl- in the water instead of dumping in liquid or granular chlorine.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Thank you so much for the info. I would like to have a salt unit, but at this time it is not affordable for me. I hearing so much about how bad the bleach is for your body and how NC is hot in the summer and burns out the chemicals faster and that is why I questioned about it.
    Aug 2010
    Dallas, TX
    4,052
    If you bleach correctly, it won't even be perceivable. What most folks think is a pool with too much chlorine is actually almost always a pool without enough chlorine. And balanced correctly, it doesn't take a high ppm to chlorinate correctly.
    Mar 2007
    San Rafael, CA USA
    12,082
    Start by reading the Pool School so you can learn how to properly maintain the pool. It sounds like you did well in the past, but be sure to understand the difference between using Trichlor pucks/tabs vs. using chlorinating liquid or bleach and also learn the appropriate Free Chlorine (FC) level for the Cyanuric Acid (CYA) level to prevent algae growth and to have a sanitary pool.
    Jun 2007
    Houston, Texas
    209
    I echo Chem Geeks recommendation. Read and learn so you can understand what your doing. Once you learn the BBB method you will always have a sparkling pool. The only reason I went to a SWG was because I was too lazy to keep using liquid bleach. It's more convenient. It's also more cost effective for me but it took a while to recoup the investment.
    36,000 gallon IG Gunite (40 x 20), 1.5 HP Hayward pump, Pentair Nautilus NS-48 DE filter, 2 skimmers, 12 - (2 x 20) Fafco Solar Panels (Goldline controller not hooked up yet), Hayward Swimpure Plus SWG, Blue Pearl Robot cleaner. New Dr. Wellness X-12 standalone Lifestyle Spa.
