Thread: Dirt Blaster Automatic Cleaner?
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    Have any of you heard of this product? I was thinking about purchasing it. My pool kit came with a vacuum head but I think I could use a better one.
    14,700 gal. 14 x 28 rectangle with 2R IG by Hydra Pools, 1 hp Hayward Maxflow ll, Hayward 24" Sand Filter, Aquarite Electronic SWG, one Aqua Genie Complete Skimmer, two main drains, four returns, 2 spa jets in steps, 30ml Tidewater liner. Taylor K-2006 Test Kit
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    Re: Dirt Blaster Automatic Cleaner?
    Well, I did some searching. This item is also known as the Manta Ray. From reading several reviews most say it is not worth it. That it gets stuck and then leaves black marks, especially in corners. Guess I will stick to my basic vacuum head for now.
    Aug 2010
    Connecticut
    1
    We had used the Manta which we inherited when we bought our house back in 1998. The vacuum has done a great job and has been fairly quick, taking about 1 1/2 hours to clean a 15x25 52" above ground pool. This year, the unit has not been doing so well. The diaphram is still in good condition, it may be related to the house. I'm going to try another hose and if all else failed, will be searching of a replacement vacuum.
    I will say, the model we have is from 1997. Since then, I believe Zodiac had bought them out so I am not sure about the newer models
    15x25 AGP, Hayward Sand Filter, Intex SWG
