Results 1 to 14 of 14
Thread: Can I just use the skimmers to clear up the pool?
    Apr 2010
    Syracuse, NY
    103
    We took the tarp off the pool yesterday, and the water is dirty filthy brown! Last year it was good, but this year with all the rain, we had ground water flooding into the pool, under the tarp, several times. I tested a sample and there is 0 FC and 0 CYA. I know there are some leaves in the bottom, and I can only see a couple of feet down into the pool. I'd like to try and clear the water a little. Can I run the filter just using the skimmers to clear the pool enough to see down into it? I'm worried about the main drain sucking in too many leaves. Or should I use my leaf basket by feel and remove as many leaves as possible from around the main drain, and then use the skimmers and drain 50/50 to begin clearing the pool? Thanks much.
    20,000 gal., Jacuzzi 250L Laser Sand Filter, inground w/vinyl liner, 1hp pump motor, TF-100 Test Kit.
    Apr 2011
    Seattle
    31
    Re: Can I just use the skimmers to clear up the pool?
    I would do both, filter through the skimmers while you scoop out whatever you can.
    20k gallon free form plaster pool with a spill over spa, sand filter, Master Pools in floor cleaner, Jandy PDA and Jandy Lite2 natural gas heater.
    Apr 2011
    Seattle
    31
    Although if your plumbing is anything like mine, blocking off the main drain with leaves is functionally no different than closing the valve on the pad. So perhaps you should filter through the skimmer and the main since the main is going to get the scummiest water and bring your visibility up faster. Just keep an eye on the pump basket.
    22,544
    If you're concerned with plugging the MD and then having to unplug it later, you can just use the skimmers to clear the pool. Raking as much as you can with a leaf net makes things go much faster, so I'd do that in addition to running the filter.
    Us AGPer's only have the skimmers all the time.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Apr 2010
    Syracuse, NY
    103
    Thanks to all for the fast responses. I have some stabilizer, and some liquid chlorine. My pH is north of 8, but I'll probably wait until I use the stabilizer to adjust it. This is also probably a good time to try and get rid of some hockey pucks. They will add stabilizer and lower the pH a little. Time to stop talking, and roll up my sleeves. Thanks again.
    22,544
    If your pH is high, that's the first thing you should adjust. Go ahead and add some muriatic acid to bring it down to the mid 7's.
    Apr 2010
    Syracuse, NY
    103
    Just curious. My pH is only about 1 point high. Is there much of a downside to waiting to see how much the stabilizer and pucks bring it down? Thanks.
    Mar 2009
    Charlotte, NC
    539
    Quote Originally Posted by edweather
    Yes, getting the pH right is very important. Unless a moderater says otherwise ( so wait till they give their opinion), I'd get that pH down first or now.
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    You're going to have to shock, and that's a process that can take a while, not just a one-time deal. Remember, pH will read wrong at shock levels, so you need to get it right before you start shocking, and then ignore it until shocking is done.
    22,544
    A pH 'north of 8' is not just one point high. Remember pH is a logarithmic scale.
    Stabilizer and trichlor probably won't bring your overall pH down much and since you're going to have to shock you need to adjust it first. Add enough muriatic acid to get it to the mid 7's. Since we don't know what the rest of the test results are nor how you're testing, we can't say how much effect the chems will have.
    Apr 2010
    Syracuse, NY
    103
    Ok, thanks. I forgot that the pH scale is logrithmic. I use the TF-100 tesk kit. I mentioned in my first post that the FC is 0 and the CYA is 0. My pH is 8.4. I didn't test for TA yet it's usually pretty high though.) Using the pool calculator the pool needs about 1.25 gallons of Muriatic Acid to drop the pH from 8.4 to 7.5. Is this about right? I'll probably add a gallon of acid to start, and recheck the pH. Thanks again.
    22,544
    Without knowing your TA the pH calc can be way off. I'd add about half of what the PC says and see what that does.
    Apr 2010
    Syracuse, NY
    103
    OK. I can test the TA also & input the results into the calculator. Not a problem. Thanks.
    Apr 2010
    Syracuse, NY
    103
    Note to self. Next year don't add anything until I run the pump a little and circulate all the water in the pool, then do the initial test. I think there was a lot of rain water on top, and old pool water on the bottom. I only added 3 quarts of Muriatic acid, and 4 lbs of stabilizer. Originally my test #'s were 0 FC, 0 CYA, 8.4 pH. Now I have a CYA of 50, and a pH of 6.4, with a TA of 60. It's hard to believe that the little amount of acid and stabilizer did all that. Oh well, live and learn...no biggie. The pump has been running for 24 hrs now and the pool is 100% clearer, but still a ways to go. When I'm done shocking, I'll adjust the pH, and TA again. I'll be doing a couple of backwashings and a lot of vaccuuming to waste in the near future, then refilling with the hose. That should help my pH, TA, and CYA. Right now the water table is very high and my liner is practically floating. It'll probably be a week or so, without rain, until the liner settles.
