Results 1 to 9 of 9
Thread: return jet
    Aug 2010
    Leipsic, Ohio
    24
    return jet
    I have a standard eyeball return jet (I beleive) and would like to add a T fitting at return jet (remove just eyeball) and relocate original jet to end of T fitting and add pipe down to bottom of pool with 90 degree fitting and add second jet inside of pool.
    My trouble is how to adapt to original return inside pool. Any and all help would be appreciated.
    12,000 gal. 24' x48"AGP, hayward power-flo lx 1Hp. pump Hayward S244T 24" sand filter system.
    use BBB method and love it!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: return jet
    Should be just a standard 1.5 inch female connection. Unscrew what you have and take a gander at it. You could just buy a 1.5 threaded male adapter and come off of that with a T connection.
    22,553
    Re: return jet
    The standard return jet uses 1½" pipe threads, so all you need is a 1½" Close Threaded Nipple, a 1½" Threaded Tee, a 1½" Threaded Male Adapter, a 1½" Female Threaded Elbow, some 1½" pipe and two (2) eyeball fittings and you should be good to go.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Re: return jet
    Quote Originally Posted by siebo
    Hi siebo,
    As Bama and woody said it is easy. I have an Intex pool but I did the exact same thing to my pool last year. Here is the link.
    http://www.troublefreepool.com/secon...ml?hilit=intex
    Hope this helps.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    Aug 2010
    Leipsic, Ohio
    24
    Re: return jet
    Was hoping that I could just remove nut that holds eyeball and remove eyeball and thread 1 1/2" pipe into it. Thanks for info and was kinda looking for a pic of the eyeball assy. as I didn't drain down and pool is not open yet. Trying to get things together before hand.
    22,553
    Re: return jet
    You can do exactly that. Remove the eyeball assembly which includes the ball ring the eyeball itself and the holder that screws into the fitting. The fitting is 1½" female pipe threads.
    Aug 2010
    Leipsic, Ohio
    24
    Re: return jet
    looked at my fitting and it does not look like center turns out. looks as it is all molded.
    May 2011
    lebanon tn
    370
    Re: return jet
    can you show a picture? If you don't have the holder, someone might recognize what you do have...
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    22,553
    Re: return jet
    Does it have threads on the outside when you take the eyeball out?
