Thread: Solar Cover 8 or 12 mil
    Is there a big difference? Is there anything I should be looking for in a SOLAR cover?
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    Re: Solar Cover 8 or 12 mil
    My experience is that they all fail after about two years, so I just get whatever is less expensive.
    so it doesnt matter if its 8 or 12 mil?
    Bel Air, MD 21015
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    12 mil is heavier. Retains heat a little bit better. You have to determine what your needs are in a cover and then go from there. Darker more opaque ones help cut back on FC loss to sunlight. Clear ones allow more light to get thru which may heat the water faster than a darker cover. The main thing they do however, is retain heat at night that is gained during the day. I have had several kind, they don't last more than 2-3 seasons regardless of the thickness, etc. so I now don't spend a fortune. I like my blue/black combo.
    Can you put your pool specs/equipment in your signature... go to User Control Panel, then Profile, then Edit Signature.
