Results 1 to 9 of 9
Thread: intex help
    intex help
    OK iv got a 24x48 intex metal frame pool. I called to get the frame parts and was told that pool was discontinued . can i use the frame parts off of the 18x48? i just need the T-bar and 1 leg.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: intex help
    The curve on the T bar for an 18' may be tighter than the curve on your existing pool. You might try locating a used 24' intex that someone is getting rid of on ebay or craigslist.
    We have several intex owners here that may have additional solutions for you.
    Love TFP? Become a
    TFP Supporter!
    Re: intex help
    I have been looking on craigslist. i even put an add in the wanted post. if i cant find nothing its been a good run put the pool up in 2001 and have never taken it down.
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Re: intex help
    Quote Originally Posted by mpknls
    Hi mpknls!
    I have done some looking around and can't find any of the "T" bars for your pool. As zea3 said the curve for the 18' may be too tight for the 24', but you never know. I know the Intex Ultra Frame pools size 16' and the 20' both use the same "T" bar and there is a 4' difference in size. If the pool is still in good shape it may be worth a shot to try the 18' "T" bar on the pool.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    May 2011
    lebanon tn
    370
    Re: intex help
    I would try the 18, especially if only 1...
    my old intex frame pool had a lot of play in the pipe connections, so even if slightly tighter bend should work!
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    Re: intex help
    thanks to all for the replies. i just found a 24X52 intex used 1 summer for $200.
    crookm11's Avatar
    Jun 2010
    422
    Re: intex help
    Great find!! Is it the Ultra Frame?
    Mark Crook
    May 2011
    lebanon tn
    370
    Re: intex help
    sounds like one for install, one for parts!
    Re: intex help
    Quote Originally Posted by crookm11
    no its just the metal frame
