Thread: Pool company water test
    The pool company by me offers free water testing. How accurate is that versus like a Taylor test kit?
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    Apr 2009
    Northeast Ohio
    221
    Re: Pool company water test
    It varies. It depends on a few things like what kind of testing they use. For example, my pool store used the BioGard Alex system that uses a strip dipped in the water, but then a computer to read the strip. Test strips, even when used in the store are often inaccurate (mine varied widely). Some stores actually use the drop tests similar to the ones found in the Taylor K-2006 or TF100, but even if they do use those, it's going to depend somewhat on the person doing the test and their experience.
    What you're likely to find is that getting a good test kit of your own (K-2006 or TF100) and learning to use it, you will KNOW you have accurate results everytime and be able to do the tests on your schedule.
    -- Pete
    32x16 ft Grecian rectangular vinyl pool 8ft on deep end - 19000 gal. 18" Hayward S-240 sand filter. 250K BTU Pentair MasterTemp heater. Hayward 3/4 HP Super Pump.
    Quote Originally Posted by loughps
    -- Pete
    thanks a bunch!
    Bel Air, MD 21015
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Even if they use a good test kit, remember that they are in business to sell you chemicals. Will they take the time to swirl the CH test long enough, or will they declare it low and direct you to the bucket o'calcium?
    It won't take much reading here to stumble across posts wherein someone left the pool store $200 lighter and the pool remained unchanged. And then they hit the internet and found this place.
