Thread: Different Types of Manual Vacuum Heads?
    Hi, just opening my pool for the first time. I have just under 20K of water, Vinyl liner. Used the manual suction vacuum head that came with the pool and worked great. Not looking for anything automatic, however are there other manual suction vacuum heads I can get for vinyl liner pools?
    Thanks
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Different Types of Manual Vacuum Heads?
    What kind do you have? I've only seen the brush kinds, in triangle and rectangle-ish shapes. Are you not happy with it for some reason?
    Aug 2007
    near the swamp
    806
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I have not used that type, but my gut feeling is it will break within a year. Overall there are not a lot of variation on style, some long thin brush types, also traditional triangle types, was well as ones roughtly like the one shown in the photo above. More of an issue is going to be build quality, the most common point to break is where the handle attaches.
    Mine is smaller and triangle like. I find that the small head on mine makes the job long. I'm not looking for a robot and not sure if a suction type brush (ie. kreepy krawly) is worth the cost.
